w87will Posted August 10, 2008 Report Posted August 10, 2008 I have My horns hooked up to a push switch which is wired straight to the battery and horn. When I start my Jeep up fresh after I havnt been driving, The horns will work fine. After I turn my system up for alittle while the horns will not work, nor will they work while the system is playing. Also when system is off...when I press the horn button I can hear the subs pulse? I was thinking maybe a relay is needed, but not sure if that will fix it. Any Ideas?
w87will Posted August 11, 2008 Author Report Posted August 11, 2008 Im still stumped Cant figure out whats wrong.
w87will Posted August 11, 2008 Author Report Posted August 11, 2008 Just added acouple batteries to the back. So I stay in the 12s, 13s all the time. But even when I turn the system off They still wont work.
duct_tape123 Posted August 11, 2008 Report Posted August 11, 2008 You don't have any other lines tapped into the B+ going to the horn button do you?
w87will Posted August 11, 2008 Author Report Posted August 11, 2008 Only things going to the horn button are a Positive from the battery then the other prong goes to the positve from the horn solenoid.
