Blown Subs?
ARMYSGT_D
when my subs are hooked up to power they make a sound like a tv makes when the cable is unplugged or goes out that loud scratchy sound
i hooked multiple rca up to them but they nake the same sound when hooked up to my mids and high amps they are fine
does this sound like blown subs or amps
they are 2 15 ssd whith a rf t1k on each at 2 ohms i think i was clipping the hell out of the signal
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
white noise? Ouch yeah Id say you have a little problem... plug your mid rca to the sub output of your deck NOT TOO LOUD! and see if maybe its your output on the deck and then plug sub amp to a spare speaker not too loud again and see if it still does it that will tell where the problem is coming from hopefully. But my guess is your amp is fucked
Some people need a sympathetic pat... on the head...with my hammer
Scientia est Vox
DONT BE AFRAID TO USE THE SEARCH BUTTON!!!
SMD SUPER BUYER/SELLER
i did that it was fine i did the amp on another speaker it was fine did the same thing i tried isolating the amps and sub str8 white noise
at first it would only do that once i raised the volume to 10 but now they do it soon as the amps on
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
i did .
no noise
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
i hooked the subs up to someone elses amp white noise i think i burnt up the fi's
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
yeah that would be my guess Slinkied coils.
put your DMM on your speaker leads and see what it says, of it has some outragouse number they are TOAST
  • Who's Online   0 Members, 0 Anonymous, 848 Guests (See full list)
