I'm about to hookup my old system (juz a mono amp and a single orion 12) to my brother's new car, a 2008 Accord. He has stock HU, which i dont want to mess with. My question are:
-where is the best place for me to hook up the remote wire while minimizing any modification to the vehicle's electrical?
-Can I juz hook it up somewhere in the fuse box? If yes...where? and how, juz trap the wire with one of the fuses?
I've installed amps before but only to a car with an aftermarket HU and a remote wire output. Although my current car, my remote wire is hooked up to the ignition, my friend hooked this up for me. Plust I really do not want to mess with my brother's ignition harness anyway.
Thank you guys in advance.
My Soundz:
'06 ACCoRD
Diamond Hex (front)........................Diamond 2ch x 100Wrms............................Ought-guage Power wire and BIG THREE
Diamond 6x9 (rear deck).................AudioQue AQ1200d @ 1ohm........................MTX re-Q (sound processor for stock HU)
CDT tweets (rear doors)..................Alpine 4ch x 45Wrms.................................Clarion 7band EQ
TWO Diamond D6 12" DVC 4ohm
Coming soon upgrades:
Batts
dynamat trunk kit
no help?
My Soundz:
'06 ACCoRD
Batts
dynamat trunk kit
Usually when you put a system in a car with the stock h/u u have to use the little wiring harness that comes with some amps, looks like speaker wires with a plug on the end of it, and I think thats supposed to act as your RCA's and your remote not completely sure though
1997 4 Runner
Alpine CDA-9886
4 Fi Audio X Series 12's
1 Crunch GP3000D Pro
DC Power Inc. Alternator(Kickin out 15+ volts!)
As far as for signal...i'm juz using an LOC to tap in the rear speaker wires. I juz not sure about the remote turn on wire.
My Soundz:
'06 ACCoRD
Batts
dynamat trunk kit
Oh damn i just forgot you can wire it to a switch, thats what i did in my truck, run a wire from a constant source whent he ignition is on in the fusebox i.e. the radio fuse and put a switch on it so he can turn it on or off anytime he likes
1997 4 Runner
Alpine CDA-9886
Oh ok. But I kinda want to have the amps turn off automatically when he shuts off the car. Cuz he'll probably forget to turn-off the amp and that would drain the batt.
My Soundz:
'06 ACCoRD
Batts
dynamat trunk kit
Hi there...you can run the remote to the fuse box, just make sure u run it to a slot that only receives power when the car is on ;)
Good luck mate...
Eclipse cd7000
Good luck mate...
Cool....that's what i wanna clear-out. Now i imma take a look at his manual to figureout the fusebox layout. THAnks guys.
My Soundz:
'06 ACCoRD
Batts
dynamat trunk kit
o and one more thing...u shouldnt need but a 1 or two amp fuse on it...
Eclipse cd7000
cool...i'll stop by radio shack later today.
My Soundz:
'06 ACCoRD
Batts
dynamat trunk kit
  • Who's Online   0 Members, 0 Anonymous, 883 Guests (See full list)
