jonnylowkon Posted August 18, 2008 Report Posted August 18, 2008 ok so i have a 250 mechman alt which will be here wensday along 2 powermaster 3400's ... im running 2 single 1/0 from the alt to the redtop which will be fused .. then im running 2 single 1/0 which will be fused(any recommendations on fuses size needed?) also to the back of my truck in which will one will be connect to each of the 3400's now to my question the 2 sundown 3000's will be just above the 3400's and ill be running about 6" positive side or less from one 3400 to one sd 3000 and the other sd3000 to the other 3400... do i need to fuse that 6" of wire between the amps and the 3400's? thanx for any help guys .. 250 amp mechman alt Sundown 100.4D Sundown 1500v2 now goin to the cruze Sundown ZV3 12d2 Sundown sa6.5cs X2 Kenwood X597 Trying something new 2011 Chevy Cruze X8 1500v2
jonnylowkon Posted August 18, 2008 Author Report Posted August 18, 2008 2 125 amp fuses from the alt to the front battery and then another pair of 150 amp fuses from the front battery to the rear batteries? 250 amp mechman alt Sundown 100.4D Sundown 1500v2 now goin to the cruze Sundown ZV3 12d2 Sundown sa6.5cs X2 Kenwood X597 Trying something new 2011 Chevy Cruze X8 1500v2
dmanson Posted August 18, 2008 Report Posted August 18, 2008 i'm sure the sundown 3000ds call for a 300 amp fuse and that's what you should be using after the underhood battery and before the rear battery. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
eaglescorpio1 Posted August 18, 2008 Report Posted August 18, 2008 I definately recommend fusing the 6" lengths. You NEVER know what could happen. If the positive cable for some reason pulls out of the amplifier connection, you don't want to lose all that you have invested over a couple $10 fuses. Loud as f*ck, and sounds good doing it. Team built from here on out!!!! BIG things to come......... Missing link is the shite!!!
spl explorer Posted August 18, 2008 Report Posted August 18, 2008 Always have a fuse installed b4 the amps! And yeah the 3000Ds ask for a 300A fuse but Jacob says you wouldn’t need a fuse bigger then a 250 if you play music and don’t run the amps below 1ohm. Rollerz Only - Sacramento Chapter. 6 Time Lowrider Magazine club of the year 94 Xploder on 22s - Gutted for now... 87 Cadillac Fleetwood Brougham on hydros, fully euroed out Tookie blue *ROLLERZ ONLY MAFIA* Crankin the volume knob and hittin switches. http://www.rollerzonly.com
dmanson Posted August 18, 2008 Report Posted August 18, 2008 Always have a fuse installed b4 the amps! And yeah the 3000Ds ask for a 300A fuse but Jacob says you wouldn’t need a fuse bigger then a 250 if you play music and don’t run the amps below 1ohm. and that's if he plays it at 1 ohm. why not go ahead and throw a couple of good 300s in there now vs spending more money on fuses down the road ... wouldn't hurt. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
spl explorer Posted August 18, 2008 Report Posted August 18, 2008 and that's if he plays it at 1 ohm. why not go ahead and throw a couple of good 300s in there now vs spending more money on fuses down the road ... wouldn't hurt. Agreed 100%. Just telling him what’s up. Overkill never killed anyone Rollerz Only - Sacramento Chapter. 6 Time Lowrider Magazine club of the year 94 Xploder on 22s - Gutted for now... 87 Cadillac Fleetwood Brougham on hydros, fully euroed out Tookie blue *ROLLERZ ONLY MAFIA* Crankin the volume knob and hittin switches. http://www.rollerzonly.com
audioaddiction863 Posted August 18, 2008 Report Posted August 18, 2008 if it is a daily driver fuse everything. the only time i dont overfuse is if it is a competition trailer queen. Its all about the Install !!!! http://www.youtube.com/user/audioaddiction863 Bass Race Florida State Champ runner up 139.9 2008 Bass Boxing Florida State Champ runner up Middleweight 2008
jonnylowkon Posted August 18, 2008 Author Report Posted August 18, 2008 right on fused it will be thanx guys for the advice ... this forum is by far the most friendliest and most helpfull.... im a loyal fan for sure 250 amp mechman alt Sundown 100.4D Sundown 1500v2 now goin to the cruze Sundown ZV3 12d2 Sundown sa6.5cs X2 Kenwood X597 Trying something new 2011 Chevy Cruze X8 1500v2
