what if the manual doesnt have the sub displacement? cant you do something with the Vas measurement?
not to my knowledge..
copied obviously
Volume Acoustic Suspension. A volume of air in an enclosure that has the same resistance characteristic in acoustic terms as the speaker's suspension in mechanical terms. This is a factor taken into account when designing enclosures. It specifies the optimum internal volume of the enclosure.
so...if the VAS of, ex my RF P2 is about 2.8cuft. that means that i make a box to 2.8cuft? because crutchfield or some similar site said that the rec. box size is 1.7
VAS is not what to build an enclosure to. You will need it when using T/S parameters for certain calculators, but again it is not the size you build your box to. What brand and model subs are you going to use, maybe we can help find your info.
