alright i have two cadence amps, i dont remember the model number but it should be in my sig. well today one side of my wall stopped working, checked all my connections everything was ok. i thought faulty cheap ass speaker wire, changed wire still nothing.
the amp powers on, and if i switch the speaker wire from the bad amp to the good amp that side of my wall works. i checked the board and everything looks ok, no red light-protection-
is there a way to test if it is bad? im kind of fucked since the last comp i can go to is on sunday and its the middle of the week. any help or ideas would be greatly appriciated, i need this working otherwise i have no bass/no chance at the local comp.
today is just full of bad news
thanks in advance
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
6 soon to be 12 12" hifonics hfi12d4's
shit ton-o-wire
Blurred Vision Audio
Team SMD
feedback/refs. clicky!-
is there a way to hook my dmm up to the speaker channels and see if there is any signal comming from them? i dont think it would matter subs still wont work when played on that amp for some reason
1992 cavalier build
1992 blazer s10
kenwood cd
hifonics hfi2500d
shit ton-o-wire
Team SMD
Sounds like you blew your inputs/outputs of the amp I have seen this happen amp turns on no protect but that's all it does is give you a pretty green lights on the amp I saw do this the inputs where jacked
