i have questions on woofer cone area's & loudness from say 2 10's & 1 12. thanks guys!!!
2 RF PUNCH P1 10" VS 1 RF PUNCH P1 12"???
2 RF PUNCH P1 10" VS 1 RF PUNCH P2 10"???
2 RF PUNCH P1 10" VS 1 RF PUNCH P2 12"???
2 15" Kicker L7's + Hifonics BXI 2006
So many times we still hear that doubling the power gets us 3dB and doubling the cone area gets us another 3dB.
It is a MYTH.
It is untrue!
Electrons flow through our wires to our speakers.
The electrons are changed to electromagnetic energy.
The electromagnetic energy works with permanent magnet energy to make a speaker cone move.
The movement vibrates air and we have sound..
Doubling the power into the speaker motor may get us 3dB more sound to our ears, but again it may not!
Just like dumping twice the gasoline and twice the oxygen into our cars motor may not make us go twice as fast.
It may not, because there are so many variables between the point of the energy being electrons and the energy making it to our ears. There are several variables that may not always have the same value and thus it is impossible to guarantee that a 3dB increase will occur. For instance a loudspeaker motor is not entirely linear, that means if we double the power to it then it may give us 3dB or it may give us less than 3dB depending on things like is the voice coil in the gap at the most efficient spot? Or is the speaker suspension restricting the speaker movement when you add this extra power (it always does!)..?  Or does the acoustic suspension of our box restrict the cone movement (it always does!)..?
Along this path from electrons to sound, there is also a lot of our energy that is turned to heat and the heat does not translate to more sound, so there is some loss, quite a bit as a matter of fact..
So, to say doubling the power will always get you 3dB is just a guess at best!
Defiantly not a law of physics! Definitely not always true.
But unfortunately, a lot of folks seem to spread this MYTH as if it were fact.
Now,  Cone area!
Cone area is another MYTH, although like power it is very important, it is still just one variable out of many that have to do with getting sound to our ears.
Many say doubling your cone area will get you 3dB.
This is UNTRUE as well.
It is true that the cone vibrates the air to make sound,  and if we had double the cone area ALSO vibrating the air making the same sound then we might have 3dB more sound!
But we did more here than to simply change cone area!
We added cone area that was already playing the same sound!
So that means that in addition to cone area we ALSO added a motor and the power to drive that motor so it would move the cone the same amount as the first cone!
We cant easily just ADD CONE AREA!
And if we did by just gluing more cone area to an existing cone then we would have a problem in that the cone area would add mass, thus needing more power to move the extra weight!  So it cant be JUST cone area!
PLUS!
We can play a 15 inch speaker at 100dB and then play a 10inch speaker at 100dB and we will achieve 3dB more and we can see we DID NOT double the cone area!
Or we can use a 15 inch speaker and have a fat lady sing the same song at the same amplitude and we would still get a 3dB increase, and we have to ask, where is her cone area? And/or where is her power and it is double that used by the 15?  Almost certainly not!
So you see, the POWER MYTH and the CONE AREA MYTH  although based in facts are often misused in the car audio world and are easily proven to be untrue..
But don’t loose all hope!  there is some truth!
The truth to the physics of sound is actually much simpler!
1. Adding one sound to another sound of the same amplitude (volume) will gain you 3dB.
2. Adding one sound to another sound of the same amplitude and correlated will gain you 6dB.
(correlated means exactly the same phase, and likely to occur with the long wavelength of bass notes in our cars)…
How can things be simpler than that?
Blame these things on the laws of physics of how two or more sounds work together, not
on cone area or power alone.
btw I stole that from here    http://www.installer.com/tech/
AS you can see the question you pose has lots of varibles.  my suggestion is get the highest quality you can afford.  If you can only afford one good 12" now then do that and add more later.  For example if I can only spend $200 on subs I would get the best one I could not 2/3/4 low quality ones.  Simply put don't go with the p1 IMHO they are as bad as it gets. If you want RF try to step up to p3 or T1 or at least the P2
i bought my p1's for $65 each. i thought they would be garbage cuz of the price and power handling.
seriously i have nothing to complain about. they pound quite great & pour out tons of bass. i have mine
in a medium sized ported box. im a newbie but i get tons of looks when im driving with them
cranked up. there is not one person especially on stop lights that dont stare. i took my friends
2 12" mtx mzs subs with out any stress. he got suprised how loud it sounded in my van. they
are so underated from people who really dont have the punch series. i read so much people judging them saying
that they are a piece of junk and cant do nuttin. from the people that have them know what im talking about.
so u gotta listen to it first in the right box, tunning, and vehicle. thats just my reasons.
what system u running.. just wondering
It is a MYTH.
It is untrue!
Now,  Cone area!
PLUS!
WTF?????????????????
Wow, that was horrible.
It gave me a headache.  Makes no sense at all.
If you need help deciding on what RF woofers to purchase, I help you out a little...
Save just a little bit more and get 2 decent 10's or a nice 15" if you have the room..
What kind of car?
What is the budget?
Do you all ready have some equipment? amp, wire etc????
Are you looking for the loudest setup within this budget or more towards it sounding good on a certain type of music, ie: rock?
What type of music do you listen to?
Ok go with that for now.
it doesnt make sense, because what they say isnt true, ask any diehard spl guy.
your not allways gonna gain 3db's thats a given, but if you build the proper enclosure when you double up your cone area and give each speaker the right power your gonna gain 3db's or atleast be close to it.
test the theory youself and see if it's true or not, Im willing to bet money that you gain close to 3db's
and I believe he was asking the guy who first posted what he was looking for and what kinda budget he had.
If you re-read it does say that.
Quote "1. Adding one sound to another sound of the same amplitude (volume) will gain you 3dB. "
It explains that not JUST adding cone are OR power will create gains. Basically you need both.
Also, I can't find it right now but, cone area is not just the size of the cone but how much it moves as well.
So. lets say I have 2 15's running on 750 watts each.
then I add 750 watts to each sub for a total of 1500 watts to each, I wont gain 3 db's ??
or I have 1500 watts going to 1 15  and I then add another 15 to make it 750 to each I wont gain 3db's?
I bet I gain in both examples.
I can actually prove it, for instance, my second build, 2 12's on a BXI1206D = 134.1 dbs
2 15's on the same amp I did a 143.3 a 9 db gain  so your right I wont gain 3 dbs  ;D
I can actually show prof of these gains via my DbDrag stats if need be, also 2 15's on 1200 watts 143.3
2 15's on 3kw 148.4 so  I just shot down there theory.
  • Who's Online   0 Members, 0 Anonymous, 1639 Guests (See full list)
