i will i think i'm gonna go find some screw up doors to do,and see how much resin i have left,im accepting all ideas on my doors,speaker location and design
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
that does sound good,i wanna do more than 1 set though
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
both my amps have 40x4 fused which is over 320 amps,so 300a with a single run of 1/0 wouldnt work would it?maybe 2 runs with 200 amp fuses?
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
Guest MegaloManiac
those are the max that the amp will draw, it will probally never go to the max if you have your amp set properly
also fuses on wires protect the wire from overheating and starting fires. So if you were to run 2 runs of 1/0awg then u would need a 300a fuse each
so i would be safe with one run and a 300 amp fuse?
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
Guest MegaloManiac
well you have the fuse dont you? so i think its safe to say you'll be safe ;)
well its 2 pa a3000db i got the fuse rating of a spl 3000d which basically the same amp,but its gonna be ran at .75 ohms,it says 1 ohm stable but i ran my other one down to .75 and it never got hot
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
i'm tryin to find what i would need to have my amp rack come up,im building it to sit flush behind my box and i cant find out what it is to use,i tried air rams and electric rams,does anyone kno what there called
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
