Hugh G. Rection Posted August 25, 2008 Report Posted August 25, 2008 ve been seeing lots of talk lately about "tapped horn" enclosures, and saw one this weekend that yielded some decently impressive results. anyone know much about designing these things? im interested in playing with the design and seeing what it would do in my particular application. Owner of BigAss Ports
12voltz+- Posted August 25, 2008 Report Posted August 25, 2008 talk to either fallen hes designs are cheaper the petes from hexibase but they are still very good. or you can talk to pete i know for a fact that both of them can design some good tapped horns...... as to say what the design is and how to explain it im not 100% sure i think there are different syles of them ...... id ask on of them
Hugh G. Rection Posted August 25, 2008 Author Report Posted August 25, 2008 talk to either fallen hes designs are cheaper the petes from hexibase id rather not get a design from someone, i design lots of enclosures myself. im just trying to find some good online resources for info. Owner of BigAss Ports
Btrash Posted August 25, 2008 Report Posted August 25, 2008 Wikipedia says: Tapped horn Both sides of a long-excursion high-power driver in a tapped horn enclosure are ported into the horn itself, with one path length long and the other short. These two paths combine in phase at the horn's mouth within the frequency range of interest. This new design is especially effective at subwoofer frequencies and offers reductions in enclosure size along with more output Some info: http://www.cowanaudio.com/ http://www.diyaudio.com/forums/showthread....;threadid=97620 http://www.diyaudio.com/forums/showthread....;threadid=97674 http://realmofexcursion.com/forum/showthread.php?t=39480
12voltz+- Posted August 25, 2008 Report Posted August 25, 2008 http://www.frugal-horn.com/plans.html http://www.quarter-wave.com/ try them but its a lot of reading lol
Forevrbumpn Posted August 25, 2008 Report Posted August 25, 2008 its a very simple concept, its already explained, its just the port and cone loading in the same exit, to put the bass in better phase, port and wooferleaving same exit also yields more output, I have a better link, Cowan really knows his stuff, cool guy http://www.cowanaudio.com/ This is the style I make, and they sound great for SQ so far, I just havent build a hardcore SPL version yet, I assume a chamber behind the woofer at the beggining of the line would work best I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
Forevrbumpn Posted August 25, 2008 Report Posted August 25, 2008 this style I have no built yet, but I will, this one has an actual air chamber behind the woofer I assume this will end the SQ/PA type sound, and go for a more boominess sound I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
Hugh G. Rection Posted August 26, 2008 Author Report Posted August 26, 2008 the big thing im wondering is how are they designed? ive seen all these wesites before, no detailed info in calculating them. from the looks of it, is it just figured like a reverse tapered 1/4 wave t-line? Owner of BigAss Ports
Forevrbumpn Posted August 26, 2008 Report Posted August 26, 2008 according to Cowan, I believe he said, (I read it once somewhere on one of the forums hes on- DIY audio I believe) and the line start off at SD, ends at SDx's 2 Simple enough Try and keep that taper/horn at a constant, and you should be ok But now you can also do a actual tline - I still call these Phase horns/phase lines, I dont understand where the tapped horn comes from, your putting the front and rear wave in perfect alignment, so anyways, yeah, you can do a standard tline to,Ive done one once, and it was more boomy than the typical design of tapped horn, but wasnt as predictable, it in my case was very high Q, peaked at tuning, and had steep slopes above and below tuning I was suprised, beause for regular tlines, that usually doesnt happen- Again, it could have been the sub I was using too? to high Q of a sub being used? But anyways, according to Cowan, its measured like a standard quarter wave, starts off at SDx's1 ends SDx's2 I have a ritual called "terminator". I crouch in the shower in the "naked terminator" pose. With eyes closed I crouch for a minute and visualize either Arnie or the guy from the 2nd movie. I then start to hum the T2 theme. Slowly I rise to a standing position and open my eyes. It helps me get through my day. The only problem is if the shower curtain sticks to my terminator leg. It sorta ruins the fantasy.
aznboi3644 Posted August 26, 2008 Report Posted August 26, 2008 You can Download Hornresp and model your own tapped horn...I'm still working on figuring out the damn program though go over to diyaudio.com They have a whole thread dedicated to tapped horns...there are plenty of people there to help. Even the guy who made the Hornresp program.
