Rebuildin' 2003 Grand Am
you will get pics when you let me win
huh?
ultra fleks
Posted Image
20ft knu kolossus power + ~7ft leftover kicker hyperflex 1/0 for ground
Posted Image
you can see the knukonceptz is tighter and uses less bundles
and kicker has thicker pvc jacket
kolossus is more flexible
Posted Image
Friday, September 5, 2008 10:46 PM
This email confirms that you have paid AudioQue ([email protected]) $389.00 USD using PayPal.
PayPal Shopping Cart Contents
Item Name: AQ2200D
Quantity: 1
Total: $389.00 USD
w00t!!
what should i do with my current stinger pro 4 gauge power wire
leave it and use as ground from front to back battery... eventually to be replaced by 1/0
sell it.... its only worth ~$20
just run the 1/0 from the front to back battery ............. keep the 4 ga for extra wire down the road ... might come in handy to help a friend out.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
amp comes tomorrow... kinda syk'd... altho i cant hook it up to anything
box is empty too... sold my sub to my friend
wish i had something to go in the box temp
might just shove a 15L7D4 in it and burp on @ 2ohms on 1300w...
or get one of usampfreaks 15" kove armagedon protos and wire it to 4 ohms for sq....
got my amp
Posted Image
its only 2.5" longer than my re 12.1
Posted Image
its a sexy little thing... came in a big box too
and i like the level control since its got a clipping indicator... i might actually use a knob after finding one that makes sense....
and the amp only has a 0-6db bass boost so goes to show ya u shouldnt need a bass boost knob... but level/gain is straight
what the hell does that have to do with me.... i dont have dd... i have his dads amp
so just because their recommened high efficiency enclosures utilize 16sqin/cuft means everyone in every application should.. no
has a little more to do with keeping port velocity down... turbulence is a big nono
Keep on topic..... w00t for my new amp!!
Dj is pretty cool guy... and Jasa makes some crazy speakers.... i wonder if Aq utilizes 8mm in the gap
  • 3 weeks later...
progress:
Thanks to my friend with the '01 eclipse (eclipsantor) i got the 1/0 to the back without fuses since i dont know exactly when i'll be installing the amp(s)
Tuesday we are getting the wood cut for both of our boxes
His is for 1 15" FiQ w/bp in 3.5cuft@30hz on rf1000bd.... old box was 3cuft@33hz did 147.6@46hz... im thinking new tl score will be ~145@44-43hz since his car peaks kinda high
Im going from 1 15" in 3.6cuft@32hz to 2 12s in 4cuft@30hz... hopeing for 146ish since i was at 144+ with the 1 15 on 1200w
dowels & resin
Posted Image
resin + mat
Posted Image
ran 1/0 knukonceptz wire, w/o fuses yet tho
fleks near front bat
Posted Image
going thru firewall, next to strut tower
Posted Image
coming out of firewall by driver left foot
Posted Image
next to drivers seat thru frame support
Posted Image
next to rear passenger up to trunk
Posted Image
extra leftover fleks in trunk so i can mount the amp anywhere
Posted Image
more to come
