superduper Posted August 28, 2008 Report Posted August 28, 2008 Im planning to run 8 blue top 35M which has 800 cca in the back and one in the front. I only have a 65 amp alt running all these batteries. will my alternator explode to death? Plans are to run 2 ddz1 to 2 18 btl's at 1ohm also my mid and high amp too soundstream604. will that be enough batts and power to run everything do im pretty sure i need ho alt. all my wires are going to be 2/0 + and - run to batteries and 1/0 from amp to batteries I have two blue top in right now, one in the back and one under the hood and the big 3 with 2/0 wires hooked up to one ddz1 and a mojo quad at 1ohm in a mk2 golf. sounds pretty good in my opinion but I want to be heard from the bass gods..
wL<3bass Posted August 28, 2008 Report Posted August 28, 2008 You need a larger alt each battery adds a 10amp load to the alt just to keep it maintained. Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
dmanson Posted August 28, 2008 Report Posted August 28, 2008 you are definitely chancing it with the stock alt and multiple battery setup. you'd better carry around a battery charger everywhere you go. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
superduper Posted August 29, 2008 Author Report Posted August 29, 2008 will the optimas and a 200 amp alt be enough to keep it at 14 volts?
dmanson Posted August 29, 2008 Report Posted August 29, 2008 will the optimas and a 200 amp alt be enough to keep it at 14 volts? 200 amp might do it (can't really say). it'll have to have a good idle charge and you'd better invest in the MLA module too 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
