go to task manager, processes and it might be called WMPlayer so click end process...make sure its not in quick launch or in ur trash taskbar and that should work
where is this so called "task manager" ? :angry03:
hold Ctrl+Alt+Del  ;)
2003 Chevy Blazer 4drPioneer AVIC-D3Memphis 9 volt line driverRE Audio XXX compsPower Acoustik NB-4 tweeters (x4 on dash)Crescendo 1000c42 Alpine Type R 15s (2 more and new box coming soon) Hifonics XXII ColossusIraggi 300A AltKinetik Hc800 up front and 2 2400s in the backKicker Hyperflex 1/0 and 4 gaugeDDM Tuning H.I.Ds35w 10,000k in projector low beams55w 12,000k high beams
:^ oh sweet jesus
:W: lol
the toolbar on the bottom by the start menu is quick launch but that shouldnt matter... check to see if its in tha toolbar by the clock on the right if so close it then try again
J. Jsig_253411.jpgMy CardomainFINISHED COBALT SS/SC DUAL ALTERNATOR PICS icon_nuts.gif
theres no such thing as too expensive when it comes to upgrades like that, because imo if you are gonna spend to upgrade then do it correctly rather then be a cheap ass ricer
Guest MegaloManiac
you know you can install winamp without uninstalling windows media player
Guest Nismofreak
Just make winamp your default player when it asks you on the install. Go to auto play and you can select which proogram you want your music to play on.
or go to your rom drive select properties and go to autoplay to select desired program
