Re Mt 18" Or Fi Btl 18"
egixxi
for streetbass purposes
45 members have voted
  1. 1. 18"
    • fi btl
      36
    • re mt
      8
    • hdc3
      1
this is trance
it can beat hard on the wright frq
http://www.youtube.com/watch?v=R2eY0VrS-cU...feature=related
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
even this
buty is al above 45 hz some haves very low notes in it,
even i hit really hard above 154 with my 28 hz box
thats what im doing aswell in holland (where i live) :spiteful:
Output Power at 1% THD+N (manual):
1 x 2130W @ 4 ohm (13.5V)
1 x 2200W @ 4 ohm (14.4V)
1 x 2268W @ 4 ohm (16V)
1 x 3350W @ 2 ohm (13.5V)
1 x 3700W @ 2 ohm (14.4V)
1 x 3846W @ 2 ohm (16V)
1 x 4770W @ 1 ohm (13.5V)
1 x 5300W @ 1 ohm (14.4V)
1 x 5520W @ 1 ohm (16V)
The page lists (RMS, unknown voltage and THD): 5500W @ 4 ohm, 7500W @ 2 ohm, 10000W @ 1 ohm
S/N Ratio: >80 dB
Damping Factor: >350 @ 80Hz (+/-5Hz)
Operating Freq. (band-width): 15Hz ~ 150Hz
Dimensions: 26.85" x 11.42" x 2.56" (68.2cm x 29cm x 6.5cm)
Max. DC current: 545A DC (1 ohm, 13.5V, 1% THD+N)
this will be the output of my amplifier... 2 18" dual 1 ohm for daily driving..
2 mt's or 2 btl?
well as you see at 16v your only getting 5520rms and you will never have 16v. youll be lucky if you stick around 13.5 on voltage drop unless you have multiple alts and batts. so really your only pushing around 4500. so youll be right around rms for the mts and fi's
2 18'' fi btls fully loaded
2 sundown saz 3000d
1 iraggi 200 amp alt
3 powermaster 3100d series batts
11.75 cuft wall after displacement tuned to 31.08 hz
ill probably upgrade my alternator to 200amp. and replace my present batteries(2 dynasty mps-100ah) to either stinger or powermaster dc3100...
space is not an issue,,
you will still not see over 5000 watts out of that amp imo. those amps are really made for competition burps on 16v systems.
2 sundown saz 3000d
Well personally i have heard the 18" BTL and it hits every note really well so i dont want to imagine what two would be like but the BTL also sounds really good on all types of music even if they dont HIT Hard per say they will sound good no matter what your listening to
Johns.jpgSuburban Coming Soon
  • Who's Online   0 Members, 0 Anonymous, 812 Guests (See full list)
