So i managed to "fix" my dad's old DMM. i set it to ohms and i read both my Kicker and RF P2 subs. the label says 4 ohms, but they registered as 2.6-3.0. that cant be normal...
-Steve
how did you fix it with duct tape????
That's why they don't deliver.
Yer ass better go sit along the side of the road and wait.
You can't expect them to travel up some dirt road in a hick / back woods town. Thats how horror movies start :D
I explain things very simply and use analogies in terms of Pickles, and grape drink, pool noodles and jackhammers...if you can't put 2 and 2 together there man, There simply is not much more I can do.
i fixed a "component" inside the dmm, it was a sheet of metal going over most of the transistors/resistors on the board. i put the metal back over the board and it started reading ohms correctly, kinda freaked me out.
but it might be the DMM, but 4 ohm subs arent supposed to read as 2.7-3 ohms...
good luck finding a speaker that says 4ohms, and meters 4 ohms
the 2.6ohms sounds kinda low, but most 4 ohm speakers will read from 3.0-4.0 ohms 2ohm coils 1.5- 2ohms, etc
Another thing, set it in ohms, and measure the resistance in the tester leads, connect red and black on the leads, and see what number comes up
deduct that from total number
i know that theres no speaker that will read 4 ohms, 6 ohms, 8 ohms on the dot.
i just touched the leads together, says .8 ohms.
so if i got 2.8 on a sub, then i would add .8 ohms and then i would come up with 3.6, that makes a little more sense now heh
thanks for that big tip man.
actually if there is already a .8 ohms resistance between the leads you would take that away from what it reads, so if it were reading 2.8 it would actually be 2, then the .8ohm resistance between the leads. Unless I am way off base.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
no youre right.
if its off by half, then I would say its possible the sub was built with wrong coils? Ive done that a few times
4ohms should read above 3ohms, but 2ohms? wow, way off
Or someone burnt the vc's down, did that when i was in school being "super cool" lol, good ol days of the DUB's....
"The Only Way IS, All The Way!"
1997 F150 - 130AMP alternator, Optima Red Top, Streetwires 0/-1G Power and Ground, 8Farad Soundstream Capacitor, Kenwood CD/Mp3 Player, Kenwood 6x8's Front and Rear
2 RE Audio SX 12" Woofers w/3.75ft3 tuned at 33Hz, US Amps XT-4000D Amp
2000 F150 - 130Amp Alternator, Kenwood CD/Mp3 Player, JBL 6.5" Components Front, JBL 6x9 Rear, Rockford 10" P1
  • Who's Online   0 Members, 0 Anonymous, 483 Guests (See full list)
