Can Someone Explain The Ohms Thing To Me
ohms are the resistance of the sub and the electrical current. depending on your sub if you have a dual or single voice coil and the amount of speakers you have you can wire them differently to make a certian ohm. the lower the ohm the more power you can make but the harder you amps have to work. most amps like around 2 ohms some 1 ohm mono. i would go to www.rockfordfosgate.com and go to the woofer wiring wizard it will make things a little clearer with diagrams. for 2400 watts i would recommend the kicker 2500.1 never really messed with one but know a few people that own one and have never really had much problems with it. if you have dual voice coils you can make your subs 2 ohm which is what this amp is made for and if single voice coil you can parallel them and make it 2 ohms as well.
2 18'' fi btls fully loaded
2 sundown saz 3000d
1 iraggi 200 amp alt
3 powermaster 3100d series batts
11.75 cuft wall after displacement tuned to 31.08 hz
ok so now i have a 4ohm 1200 watt pioneer hooked up to a fosgate punch 250... Would it still kick harder if i added another 12?
I believe the woofers you have are rated at 1200w max and iirc 400rms?
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
  • Who's Online   0 Members, 0 Anonymous, 930 Guests (See full list)
