Fi Car Audio
can somebody give me some advises or help with calculating a new box,
4 fi btls 18''
8 rf t30001bd's
want them playing on 28hz
thnx
Alpine HU 9855R IPODRE XXX compo, 2nd one is comingrockford t8004 amp ( 4 channel ) rockford (4x) T30001bd mono amps @ 0,5 ohm for dailyRE Audio 18'' MT (2 x) Enclosure is 400 LITER tuned on 28HZ28HZ - 150db TL 200731HZ - 152db TL 2007Max Score 157,4db TL 2008 @35hz----------------------------------------------NEW INSTAL UNDERCONSTRUCTION!!ALPINE HU 9855RIPOD4 RE XXX COMPONENT SETS4 RE COAXIAL SETS4 FI BTLS 18'' SUBS8 RF T4000BD'S MONO AMPS4 RF T8004 4 CHANNEL AMPS16 northstar nsb 125 batts70mm wiring10 RF 100 farad powercaps
multiply the box dimensions for 1 sub by how many subs you will use. example: if you have 1 sub that needs 3cuft to work properly, and you have 4 of them, multiply 3 x 4 to get 12cuft.
that i know
but the box also depends on the power, and like i said 4 FI BTLS 18
about 30k daily
can i take the same dimensions as for 1 mt re audio ??
yes around 6 kw daily 2 t30001bd's a sub ( fi btl 18 )
but who can help me calculating the perfect box.
it need to handle 6kw a sub and i have 4 subs.
it needs to go low aswell sombody can give me box dimensions en port dimensions please.
thnx
enough space to build but i need cu ft and port dimensions
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
