two thoughts for you... subs forward in a 24 wide by 16 tall by 24 deep with external port side ported or subs up port forward in a 28 wide by 16 tall by 20 deep
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
is that box gonna be able to do numbers if I switch out ports and tune higher?? I want it for dd and be able to tune high for comps....
Bass junkie for life!
99 eclipse under construction
91 AWD turbo talon under construction
98 extendedcab s-10 under construction
S W A T!
141.3 dash (97 sunfire)
140.3 kick (97 sunfire)
Yes, you can shorten the ports to what ever freq you want. Keep in mind that you don't want to fight the vehicles freq.
meaning my box is tuned in the 30's peaking at 41 hz hitting my best scores yet. I tried tuning it up and got crappy numbers.
Anyway, the one thing about aero ports is you can change your freq to anything you want.
I do box designs.
Ports don't ALWAYS perform best in the middle of a panel. In fact you can achieve some pretty funky stuff by loading the port off the inside of the box as often the corners are the places with the highest concentration of pressure.
10.x volts fo' life!
ok so I have the box built if I try it with the way it is will I hurt my subs at all ? Or will it just not sound good ? Or do I just scrap this box and start over? Thinking I might be able to use it as a one note wonder box if I find the right note ?
S W A T!
I have enough wood to build at least 2 more boxes ....so I want to try to find the best box for my car.. guess I have to test test test ! Thanks for all the help guys! Im sure ill be asking more question as I build.
S W A T!
  • Who's Online   1 Member, 1 Anonymous (See full list)
