ptcary Posted September 11, 2008 Report Posted September 11, 2008 On these smart intellichargers for AGM battereis, what setting do you guys use for overnight maintenance? 2, 10, 30? (It's for two Kinetik batts: HC1400 and HC600). PTCary 2003 SMD PT Cruiser 2011 Honda CBR 250R 2010 Mazda 3i Sport MY BUILD LOG
MECHMAN Posted September 11, 2008 Report Posted September 11, 2008 On these smart intellichargers for AGM battereis, what setting do you guys use for overnight maintenance? 2, 10, 30? (It's for two Kinetik batts: HC1400 and HC600). The three switches should be set at: 25 amp, AGM low, 12 volt The charger will automatically drop down into float mode once it has determined that the batteries are fully charged. Because you are charging multible batteries, set it on the 25 amp mode. You would only want to use the lesser amperage levels if you were charging a small battery, like a D975 or smaller. The manual explains all of that as well 1-888-MECHMAN www.Mechman.com [email protected]
