Ok heres where I'm at. I've become ever more fascinated by diesel engines. the noise, the smoke, the power...
I have a 1994 GMC Sonoma. this is my project truck.
It has a 2.2L 134cu. in. four cylinder. It is mated to a Borg-Warner T-5 (non world class) 5 speed, and a 3.73 rear end (I think its a GM 10-bolt.)
I've been investigating a diesel conversion.
My truck as it sits, needs the starter installed (PITA), and the transmission has to be removed and it needs a clutch installed. It is rather high mileage..
So I've found a 6.2 litre GM diesel. Its a 1982 J-code engine, which means it has no EGR, and IIRC, its 150hp, 240lb/ft of torque.
This diesel motor has 40,000 miles. Its mostly complete. It needs and injection pump (around 300 bucks) and an intake manifold (price depends)... and maybe a few other things.
I can get it for free.
It uses the same bellhousing pattern as a small block GM gas engine. It also uses the same kinda motor mount, but I will have to move the motor mounts for them to clear the starter.
I can use a 4.3L V6 S10 transmission, it will bolt up to the diesel. I will use the New Venture Gear 3500,which is a 5spd manual.. Using a transmission that came with some S-series trucks from the factory should be easier to swap.. I'd need the trans, shifter, and possibly crossmember, but it wouln't take major mods as far as I know.
The rear end will eventually be swapped out to a 94ish ford explorer 8.8 4x4 rear end.
So do you guys think I should do the diesel conversion? The diesel is mechanical, so it doesn't have a computer, and won't be too hard to wire up.
I'm going to make a new dash panel with different gauges and stuff.
Also, with the 6.2 I can get a bracket and use a 200amp generator from a humvee, I was thinking of using an alternator for the truck and the generator will charge the rear stereo batteries.
Fuel mileage will be decent aswell. I should be able to get pretty good fuel mileage, I think I should be able to get better fuel mileage than my dads 6.6L diesel silverado. I was chattin with one guy with a 6.2 in a buick roadmaster, and he gets 37ish mpg
Also I can weld myself, and my uncle is a ticketed welder who welds high pressure oil pipeline. Dads a mechanic.... should have enough help...
Edited by Gearstix
on a green note, I'd say go diesel, and do Bio fuel
save money, gain mileage and power
if you have the time and the help..then i said why not go for it.. but if you start... keeping going till you finish it.. cause it would be one hella of S-10.. and the venture 3500 aka muncie 5 speed.. just got done rebuilding one of those in my manual trans and drive train class..
good luck!
Edited by Ipod
Hustle hard, Stack paper,
It's alright, ya'll haters,
It's nothing, We major,
You see me, Hi Hater! =)
~ Manio
No joke I thought of doing this before I traded my swampper s-10 for my camaro, I did a 400 small block instead(wish I kept that motor). It should fit sounds like you have enough help. If you do it post pics I'd love to see this. Also look for a turbo once those 6.2 get turbo they get some POWA.
I've chatted with two people with 4x4 s10s with 6.5s in them.
6.2 is non turbo.
I think I'm going to supercharge it later on.... and maybe add a remote mount turbo blowing into the s/c... we'll see...
Are the NV3500s any good? I was told on S10Forum that I will bust it up.
You guys are the only people other than the diesel page/my cousin that say do it.
Its as big as a big block I think.
I'm going to be using a different rad and electric fans...
I will be doing a stud girdle to hold the mains together, might do 18:1 pistons so I can run a bit more boost.
I'm at school will chat when I get home..
thanks for the replies.
