marquettefan247 Posted September 16, 2008 Report Share Posted September 16, 2008 I am getting two 15inch ma audio 1500 xl subs. what amp should I use to maximize loudness. They are 1200 watt peak each and 600 watts rms each. I dont want my lights to dim so a capacitor would help. I am making a ported box tuned to 35hz. just help me find sumtin k thanks Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
ALPINE408 Posted September 16, 2008 Report Share Posted September 16, 2008 (edited) I would forget about the cap and buy a small audio batt instead As for amp Rf 1500bd Stetsom 2kd Sundown 1500d Us amps there are alot of amp choices get something in the 1500 watt range Just make sure its a proven 1500 watt amp then go with best price/quality amp Edited September 16, 2008 by Team Bassick (ALPINE) Quote Have you ever had your woofers blown? Link to comment Share on other sites More sharing options...
marquettefan247 Posted September 16, 2008 Author Report Share Posted September 16, 2008 I would forget about the cap and buy a small audio batt instead As for amp Rf 1500bd Stetsom 2kd Sundown 1500d Us amps there are alot of amp choices get something in the 1500 watt range Just make sure its a proven 1500 watt amp then go with best price/quality amp anything cheaper what is the stetsom 2kd couldent find it where can I find a battery Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
ChiTownTBird312 Posted September 16, 2008 Report Share Posted September 16, 2008 (edited) kinetik, stinger, xs power, even an optima battery would work. what im going to use to power my subs when i put them in is this one, i just got it a few days ago http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=18180 Edited September 17, 2008 by ChiTownTBird312 Quote Matt W. 1996 Thunderbird LX Sport 4.6 new system soon...still deciding on what to get. Link to comment Share on other sites More sharing options...
sdrawkcaB Posted September 16, 2008 Report Share Posted September 16, 2008 People here will tell you to get a battery instead of capacitors, but I have a capacitor because I have a small system. I'm only running 1200 watts... But they say get 1Farad per every 1000 watts you have. I have a Rockford Fosgate digital capacitor and it tells me my voltage at the amps and it hasn't failed me yet. As for amps, what Bassick posted above are all very good. Just make sure they do 1200 watts at the ohm load you want. Quote Custom 1977 Chevy Nova Show Car: (1) Kenwood KDC-MP638U Head Unit (10) Sony 3" in the dash (2) Rockford Fosgate P3 12" P3D412 (1) Rockford Fosgate P1000.1bd @ 1ohm (1) Rockford Fosgate PEQ Bass Remote (1) Rockford Fosgate 1 Farad Digital Capacitor RFC1D All Rockford Fosgate 4AWG Power/Ground wire Under construction: (2) Rockford Fosgate P162C 6.0" 2-Way Full-Range Speakers up front (2) Rockford Fosgate P1694C 6"x9" 4-Way Full-Range Speakers in the back EVERYTHING hidden to maintain authentic look Link to comment Share on other sites More sharing options...
marquettefan247 Posted September 16, 2008 Author Report Share Posted September 16, 2008 what are ohms m kida new to this stuffthe subs get 4 ohms each so what do I get Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
sdrawkcaB Posted September 16, 2008 Report Share Posted September 16, 2008 what are ohms m kida new to this stuffthe subs get 4 ohms each so what do I get If you have 2 subs, and the subs are "4 ohms each", and each sub has "dual voice coils," Then you can wire the subs down to 1 ohm to get the most power out of you amp. BUT you must make sure your amp is one ohm stable, or you could fry the amp. You can also wire the subs to 4 ohms, but like I said above, you need a sub that can handle at least a 4 ohm load if you go this way. But usually you won't get as much power at 4 ohms as you would at 1 ohm. (The things in italics, you can tell if your subs are this type just by looking at their description on the box they came in) Quote Custom 1977 Chevy Nova Show Car: (1) Kenwood KDC-MP638U Head Unit (10) Sony 3" in the dash (2) Rockford Fosgate P3 12" P3D412 (1) Rockford Fosgate P1000.1bd @ 1ohm (1) Rockford Fosgate PEQ Bass Remote (1) Rockford Fosgate 1 Farad Digital Capacitor RFC1D All Rockford Fosgate 4AWG Power/Ground wire Under construction: (2) Rockford Fosgate P162C 6.0" 2-Way Full-Range Speakers up front (2) Rockford Fosgate P1694C 6"x9" 4-Way Full-Range Speakers in the back EVERYTHING hidden to maintain authentic look Link to comment Share on other sites More sharing options...
marquettefan247 Posted September 17, 2008 Author Report Share Posted September 17, 2008 aight so would this amp be good http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=18180 Quote 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades Link to comment Share on other sites More sharing options...
ChiTownTBird312 Posted September 17, 2008 Report Share Posted September 17, 2008 thats the amp i just posted above....and the amp that i have. and yes it would work Quote Matt W. 1996 Thunderbird LX Sport 4.6 new system soon...still deciding on what to get. Link to comment Share on other sites More sharing options...
chill phil Posted September 17, 2008 Report Share Posted September 17, 2008 AQ 1200d Quote 2007 Nissan Xterra SE Amp: Sub: Box: Electrical: TL Scores: Link to comment Share on other sites More sharing options...
