andym85 Posted January 10, 2007 Report Posted January 10, 2007 Big 3: 1. battery negative to frame/engine block 2. alt. bracket bolt to frame/block (this is a ground, also) 3. alt. positive bolt to the postive terminal of the battery Quote i likes me some audio stuff...
Guest MegaloManiac Posted January 10, 2007 Report Posted January 10, 2007 Just be sure it don't drive you crazy by picking the stiff cable lol Make sure it flexes good www.weldingsupply.com is teh best IMO Knukoneceptz has it cheaper, price of copper has gone up over at welding supply. http://knukonceptz.com/productMaster.cfm?c...ory=KLM%20Kable quick tutorial http://www.stevemeadedesigns.com/forums/in...hp?topic=2521.0 Quote
bassmachine Posted January 10, 2007 Author Report Posted January 10, 2007 Big 3: 1. battery negative to frame/engine block 2. alt. bracket bolt to frame/block (this is a ground, also) 3. alt. positive bolt to the postive terminal of the battery Could I ground the wire coming from the frame block and coming from the negative battery together. Quote Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
Guest MegaloManiac Posted January 10, 2007 Report Posted January 10, 2007 Big 3: 1. battery negative to frame/engine block 2. alt. bracket bolt to frame/block (this is a ground, also) 3. alt. positive bolt to the postive terminal of the battery Could I ground the wire coming from the frame block and coming from the negative battery together. quick tutorial http://www.stevemeadedesigns.com/forums/in...hp?topic=2521.0 Quote
bassmachine Posted January 10, 2007 Author Report Posted January 10, 2007 thanks. :w00t: Quote Windows Xp1 40 & 120gigHDDMSI BoardUNDERCONSTRUCTION Dr. Doom aka StarScream3kDestruction at ur service
