How To.... Us Amps Md3d
Aruman
I'm a bit confuse how to Wiring two US Amps MD-3D Using the MLT Wiring as shown in the Owner manual( pics,link below)The problem is that the owners manual says the lowest Impedance is 4ohm, so that means each MD3D should see min. 2ohm, now since I have 4x RE SX 12" Dual 4, 2 subs on each Amp at 1ohm, it confuse me, because if so than the min ohm should be 2 ohm for the MLT Wiring, but they recommend 4ohm min.
And if i wired the subs in series so the final ohm is 4ohms then the subs won't get the full power they should get.
So can I wiring them at 2 ohms final ( 1ohm each amp) and still using the MLT Master/Slave Wiring, or should a set each Amp apart, or there's other way?
Here's the link: http://s109.photobucket.com/albums/n47/Aru...rent=USAmps.jpg
Anyways thanks,
Aruman.
Shaking The Neighborhood.
If each amp is 1 ohm stable I don't see why it would hurt it to run them at 2 ohms strapped. Like you said the amps would each see a 1 ohm load when they are strapped at 2 ohms. If you feel comfortable trying it, it's your decision. I might call US amps if I were you and ask them why exactly they have their manual worded that way. Otherwise you could run 2 subs per amp and then match the gains by measuring the outputs of the amps.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
  • Who's Online   1 Member, 0 Anonymous, 658 Guests (See full list)
