missinglink Posted September 24, 2008 Report Posted September 24, 2008 Just monitor the voltage when you are playing the system, don't run it below 12.8 for extended periods. x2 Our module gets you better voltage and adds anticipation as well , but as with most things electrical there are limits. If your alt can not keep up our module does not over ride the alts internal protection. It will help out alot by doing shorter burps. Adding a battery for the extra storage is always a plus. A second yellowtop would be fine if your trying to save on the cash. MLA Quote missinglinkaudio The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
usmc7980 Posted October 1, 2008 Author Report Posted October 1, 2008 So when I add my batts in the back do I run + and - then ground the amps to the rear batteries or just run + and ground the rear batts and amps to the frame? Quote
dmanson Posted October 1, 2008 Report Posted October 1, 2008 So when I add my batts in the back do I run + and - then ground the amps to the rear batteries or just run + and ground the rear batts and amps to the frame? either will work. Quote 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
