I ordered a AQ2200d and Sundown 100.4 to replace my old amps. I also ordered a MLA module the other day and right now I have a 220 amp alternator and a Yellowtop. The big 3 is done in all 0 gauge and my power runs to the amps are 0 gauge for the AQ amp and 4 gauge for the Sundown. Do you think I'll need more battery for this setup?
a couple of batteries wouldn't hurt, could only help.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Money is the only obstacle right now. I just wanted to make sure I could run everything on the 1 battery and alt for now without frying it until I can get some more batteries next month.
in that case then you should be okay until you add another battery or two in the back
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Just monitor the voltage when you are playing the system, don't run it below 12.8 for extended periods.
so with a combined fuse rating of 290 Amps for both amps what capacity batts should I be looking at? I have the 220 amp alt and MLA module but I would like to change the main battery and have whatever I need in the back also. I'm thinking a Kinetik HC1400 up front and HC1800 in the back?
  • Who's Online   0 Members, 0 Anonymous, 979 Guests (See full list)
