im getting two 15 inch Ma1500xl subs and is this amp good?
http://www.sonicelectronix.com/item_3676_M...dio+HK1398.html
1995 Ford Mustang 3.8l V6 5 Speed
Plans:
  • 2 12 inch dc Level 4s
  • DC 2.0k Amp
  • KCA 1/0 Power Amplifier Installation Kit
  • 220 Amp Alt
  • XS Power 12V D925 AGM Battery
  • Stinger Volt Gauge
  • Rockford Fosgate RCAs
  • Box built from birch. Probably tuned to 32 Hz
  • 0 gauge wiring for extra battery
  • Dynamat
“I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.”
Al McGuire
“The only mystery in life is why the kamikaze pilots wore helmets”
Al McGuire
remember this always
Close only counts in horseshoes and hand grenades
its not bad. but im pretty sure for 400 you can find a better amp than that.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
i got that in a package with the two subs and a box for three hundred so yeah. What kind of batery do I need to power it. I want a link if possible
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
I second that. there is the Audioque AQ2200d, possibly some other amps too.
Bills
KwB
Team DC Audio Midwest captain
oh if you already have it then fuck it bang it out. go for a deep cycle battery there are many brands that are marketed strictly for car audio. Kinetiks the big kid on the block and then you have stinger optima etc etc. The battery is really not any more important than the rest of your charging system though. its only as good as its weakest link. what car do you have? and what size alternator? have you done your big three?
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
200 chevy cavalier 4 door i dont have any aftermarket things yet execpt my deck. IDk what size stoc probably
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
Don't forget about powermaster. check out Darvex.com, they got stinger, powermaster, kinetik. and possibly optimas. not sure. but there is a MEADE discound when you checkout if you put meade in the coupon box i thnk it is. so thats a good deal. there is also a powermaster blowout in the Forsale section, i think its still going
Bills
KwB
a cavalier? im pretty familiar with them lol. its a 105 amp factory alt. do your big three. i was able to sustain two 1000bds off the stocker with that done. I wouldnt recommend it and would upgrade as soonas i could. If you have the 2.2 ohv engine you are in luck. you have no power but you can get a bracket made to fit a large case gm alt so you can get a big 300 amp alt. the 2.4 engine kinda sucks since its under the engine in a confined space so you can only go up to what i believe is a 200 amp in the small case. ecotec engine is very different and im not quite sure what fits it. Iknow last time i talked to dom about it the ecotec engine (well actually the ecu) shuts the alternator off at higher rpm loads to produce more power. Your best bet if you run the ecotec is to contact one of the alt guys and see what they can do for you.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
cant I just do another battery
Plans:
  • DC 2.0k Amp
  • 220 Amp Alt
  • Dynamat
Al McGuire
Al McGuire
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
