I need to find dome good battery terminals that have atleast 1 screw for ring terminals and maybe some places for set screws that i can use for the factory wiring. More screws would be better for me.
some optima batteries come with that luxury. two posts at the top and two more to the front-a perfect place for all of your stock wiring needs.
Guest MegaloManiac
I am using Kunkoncepz for Pos & Neg. I love them. well worth the money. they also come with a plastic cover.
i had a pair of those on my mustang a bit ago. couldnt remeber if they would have enough room for multiple 0ga ring terminals up top. I think im gonna give them a try again.
Guest MegaloManiac
they have 1 0awg input and 1 4awg I belive input and a screw on the top so u can screw in as many ring terminals you'd like :smile:
I kind of have a similar situation, I am running two runs of positive and two runs of negative from my Red Top in the front to my D31 Yellow Top (1 pos. and 1 neg. post) in the back.  The Two runs in the front of each positive and negative are hooked to Stinger Expert Dual 1/0 Battery Terminals.  Now when the runs get to the Yellow Top in the back, I want the two runs to go into the battery and then one run coming from the battery to the amp (V4000XD).  So what are your best suggestion for hooking basically 3 runs to each pos. and neg. terminal on the Yellow Top (2 going to the battery and one leaving the second battery to the amp) and maintaining a good/clean connection?
Guest MegaloManiac
yellow top aka deep cycle bateries and red top aka starter batts dont mix to well. you'll regret doing that unless you have it isolated from each other.
  • Who's Online   0 Members, 0 Anonymous, 3354 Guests (See full list)
