mr_kebo Posted January 8, 2007 Report Share Posted January 8, 2007 I need to find dome good battery terminals that have atleast 1 screw for ring terminals and maybe some places for set screws that i can use for the factory wiring. More screws would be better for me. Quote Link to comment Share on other sites More sharing options...
AI James Posted January 8, 2007 Report Share Posted January 8, 2007 check out ebay Quote Link to comment Share on other sites More sharing options...
Dale Posted January 8, 2007 Report Share Posted January 8, 2007 some optima batteries come with that luxury. two posts at the top and two more to the front-a perfect place for all of your stock wiring needs. Quote Link to comment Share on other sites More sharing options...
mr_kebo Posted January 8, 2007 Author Report Share Posted January 8, 2007 Im goin to be running kinetiks and was wondering if they had that like some optimas. Quote Link to comment Share on other sites More sharing options...
Guest MegaloManiac Posted January 8, 2007 Report Share Posted January 8, 2007 I am using Kunkoncepz for Pos & Neg. I love them. well worth the money. they also come with a plastic cover. Quote Link to comment Share on other sites More sharing options...
mr_kebo Posted January 8, 2007 Author Report Share Posted January 8, 2007 i had a pair of those on my mustang a bit ago. couldnt remeber if they would have enough room for multiple 0ga ring terminals up top. I think im gonna give them a try again. Quote Link to comment Share on other sites More sharing options...
Guest MegaloManiac Posted January 8, 2007 Report Share Posted January 8, 2007 they have 1 0awg input and 1 4awg I belive input and a screw on the top so u can screw in as many ring terminals you'd like Quote Link to comment Share on other sites More sharing options...
subaru18 Posted January 8, 2007 Report Share Posted January 8, 2007 I kind of have a similar situation, I am running two runs of positive and two runs of negative from my Red Top in the front to my D31 Yellow Top (1 pos. and 1 neg. post) in the back. The Two runs in the front of each positive and negative are hooked to Stinger Expert Dual 1/0 Battery Terminals. Now when the runs get to the Yellow Top in the back, I want the two runs to go into the battery and then one run coming from the battery to the amp (V4000XD). So what are your best suggestion for hooking basically 3 runs to each pos. and neg. terminal on the Yellow Top (2 going to the battery and one leaving the second battery to the amp) and maintaining a good/clean connection? Quote Link to comment Share on other sites More sharing options...
Guest MegaloManiac Posted January 8, 2007 Report Share Posted January 8, 2007 I kind of have a similar situation, I am running two runs of positive and two runs of negative from my Red Top in the front to my D31 Yellow Top (1 pos. and 1 neg. post) in the back. The Two runs in the front of each positive and negative are hooked to Stinger Expert Dual 1/0 Battery Terminals. Now when the runs get to the Yellow Top in the back, I want the two runs to go into the battery and then one run coming from the battery to the amp (V4000XD). So what are your best suggestion for hooking basically 3 runs to each pos. and neg. terminal on the Yellow Top (2 going to the battery and one leaving the second battery to the amp) and maintaining a good/clean connection? yellow top aka deep cycle bateries and red top aka starter batts dont mix to well. you'll regret doing that unless you have it isolated from each other. Quote Link to comment Share on other sites More sharing options...
subaru18 Posted January 8, 2007 Report Share Posted January 8, 2007 What do you mean that they don't mix, I put the started in the starter spot and the deep cycle in the back to run the system. What is wrong with that? Quote Link to comment Share on other sites More sharing options...
