94 Civic Spl Enclosure Trunk Only
SPL KID
i'm thinking more in the lines of 1800-3600
NSPL 2001 Trunk 251-500 world champion. 2009 2nd place 0-1800 147.9 under 1800 watts. 2011 0-3601 Trunk Champion. No Typo Current 0-3600 Trunk WR Holder! 149.9 (0-1800) /147.5 (1801-3600) /???.? (3601-up) need new front window first! TEAMHIGHX-CURSIONsig-1.jpg
Learn to be quiet about what your workin on.. L O S E = (L)etting (O)thers (S)ee (E)verything
You'll want a bigger box to help the efficiency then :) Maybe 2.5-3 cubes per sub. Lots of port area still required though. Maybe 1 6" aero per sub if you can fit it.
10.x volts fo' life!
concrete that bitch.
lmfao
Alpine 9886
Polk Audio 6.5 Component db series
Elemental Designs nine.4
JL Audio 1000/1
DC Lvl 4 15" - 3.95 cu ft/tuned to 32 hz
Clarion EQS746
Stinger Voltage Meter
Optima Yellow Top (Front)
XS Power 1200 (Rear)
All KnuKonceptz Wiring
lmfao
I had really thought about it at one time.... watched couple video's of 150+'s rip open civics and crx's like paper.
I have like 2 cuft a piece now after port.
  • 4 weeks later...
Bump updates. THX goes out to TwistedImage and all those who have donated to this thread. It's getting there. Need to get my Termlab and do some testing for newest numbers!
you can build twisted images box or my box which was 1.3 louder than his lol we both have the same cars too......mine on 2 12s and 7k real watts did a 157.6 in the kick and only loses 1.3ish going from the kick to dash....... mine is 16.0x14.5x26 those are External dimensions.......2 6inch aero ports to the drivers side subs up adn box all the way to the back of the car(so subs firing straight at the trunk lid)..............i might have some pics to help ill hafta look...........
SWAT TEAM
TIM DOUGHERTY
09 USACI FINALS WORLD CHAMP TRUNK UNLIMITED 156.5db.....(157.6 in the bay but dont count cuz not recorded)
07 usaci finals 1801-3k 2nd
08 usaci finals 1801-3k 2nd
3X record holder-
USACi Stock 3K+ 155.1 legal
USACi Stock 1801-3k 156.9 legal
USACi Stock 1801-3k 160.9 OUTLAW
you got a PM... I may have to I was thinking about using the Aero's but have a comp in couple days so couldn't wait for them to come in. But the 6"s were in the original plans. I am having issues at mid volumes with subs rear waves hitting port inside the box. There's only like a inch behind one of the subs and it reverbs bad half mass. Full tilt you can't hear it or the problem goes away. I plan on upgrading subs so I need to Rebuild a box anyway as the new subs are deeper and it would cause more of a problem trying to reuse the enclosure i just built. So tomm since I have time i may build a secondary enclosure and order ports and if they come in i'll use that box instead.
did you use the box daily for music. This one sounds great except for the reverb. And it's made of Birch. What materials did you use?
I won usaci finals with the box never played music on it though...........You can go to like lowes or somewhere and get the green 6 inch PVC and heat it up and flare it thats what i have always done. also for the kick it was 58hz and on the dash it was 53 or 54hz
SWAT TEAM
TIM DOUGHERTY
3X record holder-
oh and my teammate has a 95 i think and they are alil bit different and not quite as loud i think he was a db down from me BUUUUT his car was alittle rough so thats not a good comparison........
Try sealing all the holes in the doors your door is like a shell the part right behind the door panel if you cover all those hole you should pick up atleast .5db then if you cover the speaker cut out youll gain another .3db
SWAT TEAM
TIM DOUGHERTY
3X record holder-
  • Who's Online   0 Members, 0 Anonymous, 2012 Guests (See full list)
