What Amp Would You Recomend For My Setup?
DillKil10
what ohm subs?
and you cant go wrong with RF :)
Team Devastation Mixed Martial ArtsMachado Brazilian JiujitsuOnce I lock it on there's no escape I don't train to make you tap, I train to tear your arm, leg, or head off. Its your job to tap before I can do that -Pain is only weakness leaving the body, its kill or be killed and only the strong survive...Rockford FosgateDigital DesignsFi Car AudioCrossfire Car Audio
I have two 12" Pioneer Premier Champion Series Pro subwoofers. 3000w max, 1000w rms each. I want an amp that has plenty of power, thinking towards rockford fosgate or memphis. But can you run a mono amp with 2 subs? Thanks
mono amps works wonderful with subs.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
The sub is dual 4 ohm. How do you hook up two subs with one mono amp? i don't see how its possible with just one set of pos neg speaker input.
Thanks for the responses
you're gonna have to run it down to 1 ohm... not real sure on them, sundown has some good stuff, the rockford amps are one ohm stable
this is how you'd wire..
http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=4
'98 Dodge Durango 5.9L
5% front windows, 2.5% on all backs
Alpine CDA-9883
Kicker ZX350.4
Kicker KS650's in all doors
Kicker 1/0 hyperflex
One Sundown 3000 would be awesome, it would be the easiest on the electrical. Memphis amps are power hungry and burn up if you drop volts, esp. the mojo. RF are a little less power hungry but normally will just go into protect if you drop volts.
If you build it, db's will come...
NSPL World Record Holder Trunk 0-1800 watts---147.9 with 1722 clamped watts @ 40Hz(9-20-09).
Competition Only Record Holder Trunk 0-500 watts---148.1
2006 Nissan Altima 3.5 SE
Currently Rebuilding....
My 150db Plus Trunk Build
I do box designs.
[benH] 6:24 pm: clipping doesn't really hurt subs
[benH] 6:24 pm: being an idiot is what blows subs
x2 on the sundown. and there was a thread on here a couple days ago of people burning up memphis amps due to the volt drops
Alpine CDA-9883
Kicker ZX350.4
fosgate t20001!!!!
The only thing about getting a RF T2000 is that you would have to set the gain up to 3/4 or more the get the 2000 watts depending on how strong of an amp it was. The higher you set the gains the more the demand on the eletrical....
I do box designs.
  • Who's Online   0 Members, 0 Anonymous, 1114 Guests (See full list)
