You guys are overlooking so many things..
The voltage of the amp rating is kinda major. A 160 amp rating on a amp that is rated at 12 volts, and a 160 amp fuse rating on a amp that is rated at 13.8 is two different things..
160 x 13.8 = 2208.
A amp seeing a higher voltage is kind of making the amp a little more efficent in a way, its making a bit more power with close to the same current draw.
Running a higher voltage through same fuse sizing will not blow the fuse.
The amp is clearly not 2000wrms, but it maybe close. It may do a 1600-1800 depending on how effienet it is. but it seems like a dirty amp with a higher thd rating, but runs a very simular board to the lanzar optidrive 2000d's (which is fused at 180amps and does 2000rms @ .5 ohms max).
just looking at the board on Ampguts, its looks like a very solid amp for the price
hope its not fried, or if its a B-Stock, hope you knew about it
