Start off with the HO alt and get as big as you can get like a 200-240 if you can and i recommend those because they normally have a best idle power. from there add a couple of more batteries along with that MLA module and it's a wrap.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
A HO output alternator would be a great help, but will be around $500 for something with good idle output. Adding another AGM battery in the trunk would litteraly only take minutes to install, and would be the cheapest/easiest solution. An MLA module wouldn't hurt either.
