Fi Car Audio
If your getting dual 1 ohm subs then run the sub in series for a 2 ohm load and then when you get your other sub run them at 1ohm. Or if your getting the 2 ohm models run the one @4ohm and then run them parallel for a 2 or .5 ohm load.
Alpine INA-W900
Rockford Fosgate Punch 200ix
Rockford Fosgate power T1500-1
Sundown SA-10 x2
Focal 6x8's front
Rockford Fosgate Power T1682 rear
Rockford Fosgate and Stinger Wiring
Powermaster D3400, S680
You should be fine. Just bump responsibly. I have a VFL 400.1 on my BTL 15 and it takes it like a champ. Set your gains correctly and like Pitbullx said know when to back off the volume.
Team S.S.C.
DB Drag Street A 2011 National Champ
DC Audio Dealer
Nor Cal AA Dealer
Incriminator Audio Dealer
CA Sundown Audio Dealer
[email protected]
[/q
yes it will take it thats wat im running all day daily
  • 1 month later...
Yes you can but you didnt list what options your getting with it you can give it 3k but it [mainly depends on setup and encloure]. Dont expect to get a huge enclosure around 7.5-10 cuft. giving it 3000 rms or else your [sub will unload causing the voicecoil to slam against the backplate making it bottom out destructively!!!]. I know you dont want that!!! But get the enclosure around 6-6.5 cuft and you will be fine. Im giving mine 3500 rms on a AQ3500D and the enclosure maybe will be 6.5 cuft (After displacement and after port). Like I said 3k is possible as long as your smart and know what your doing.Dont forget to set the gain right and subsonic filter and you should be cool :)
Some steps you need to follow:
Do big 3 (Beef up electricial system)
Get 2nd Battery Invest in a HO Alternator
Very Very Soon 2 Come???
(1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof)
(4):15'' Orion Hcca's
(1):Stetsom V 14K2D
(6):Kicker PKD1 (Ampkit)
Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF
(8):Screws for terminals (Better solid connection no leaks)
(1):Dynamat xtreme license plate kit
(1):Kenwood eXcelon KDC-X492
(3):300amp HO Alternators
(4):Kinetik HC 3800 Batts.
(1)Rockford Fosgate Power T8004 (For Mids & Highs)
(4)Rockford Fosgate Power T162S (Mids & Highs)
(3):Kicker PKD4 Ampkit (For Mids & Highs)
(1):Kinetik HC 1800 (under the hood or yellow top)
(1):Viper 5701 (p/n 5202V) ALARM
Big III will be done (beefing up my electrical system) etc.
Goal:154.9db-159.5db
  • 4 months later...
I run a 40.1 per sub at 0.5 ohms. 4 ft^3 per sub tuned to 34 Hz.
Brian
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
  • Who's Online   0 Members, 0 Anonymous, 2083 Guests (See full list)
