you say you drained the old fuel.....how did you drain it by dropping the tank? did you put enuff gass in theirfor the pump to be picking any fuel up....id cylce the key 10-15 times then try to start it....
inbetween the pump and the throttle body only has the filter.....
99 4runner
walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar
orion hcca 8000.1d
8 Polk audio mm 691 6x9
2 2000x4 hifonics
320 amp singer alt
3 g31
1 baby seat 1 booster seat and daily driven!
Yes I'm sure I pulled the right line from the throttle body, it was the line coming from the filter. I drained it by dropping the gas tank, and I only put about 3 gallons into it. Could it be the fuel pump relay by anychance? I'll trying putting more gas in it tomorrow and trying that technique if that doesn't work I'll replace the fuel line.
2000 Jeep Cherokee
-DC Audio
-Memphis
-Audioque
-SecondSkin
-Pioneer
-KnuKonceptz
my truck did the same shit. was a bad fuel pump.
I did not read the topic before and said check fuel pressure.
now i read it and i now say check fuel pressure.
DC.jpgDC POWER
i know with my cavalier back in the day, it would click click click but wouldn't turn, and i put a new alternator in and it worked after that, have you checked the alternator?
I'm stumped...I changed the battery, starter, fluids, and spark plugs and it will not crank. It just rolls over and over trying to start. I can hear the fuel pump so I know it's running. What else do I need to check?
i think he means its turning over.
but yea my fuel pump still made noise but was only holding like 21 psii think it needs to be near 40
DC.jpgDC POWER
I don't understand how the fuel pump can be pushing the gas all the way out the filter but not to the throttle body? I guess I can go ahead and replace it though.
Edit***Now i see your post I guess it's not putting out enough pressure, I'll go ahead and replace the pump then
Edited by JGod
2000 Jeep Cherokee
-DC Audio
-Memphis
-Audioque
-SecondSkin
-Pioneer
-KnuKonceptz
take the spark plugs out and tuch them to metal to see if it haz spark have some one turn the key and see if it haz spark you odnt have fuel geting to it
b-low
Team Deadly Hertz
Team Us Audio!
1995 s10
flip up head unit
kicker zx2500
2 15" havoc
10cubefoot box tuned at 30
145.9 on dash
148.00 windos down
