will one AudioQue AQ2200D be good for two bl 15's?
and will i need to change any of my electrical?
2004 gmc Yukon
270 amp mechman alt.
1 odyssey PC1500 up front
6 kinetik HC2400's in the back
2 18" BTL's fully loaded
2 saz-3500d's strapped
155.7db @ 38hz sealed :)
MY YOUTUBE!!!
yes that would be good power for them. You probably will need a high output alt or maybe an extra bat or two... I would just do the alt and be on my way. Out of curiousity, where are you from?
**edit: I'm not sure if those amps are underrated or not but they will only be right for the subs @ 1 ohm and 14.4 volts...
Edited by littleitaly1990
A vitrolic, megalomaniacal sadistic psychopath.
personally id run 1 per.... my bl took my z1 perty good....so i think the 2200 which actually does about 2500 is perfection for one...
99 4runner
walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar
orion hcca 8000.1d
8 Polk audio mm 691 6x9
2 2000x4 hifonics
320 amp singer alt
3 g31
1 baby seat 1 booster seat and daily driven!
are you really sure about that...I know my bl's had a lot more free space to give but 2000+ watts to one would be ridiculous overpowering and not smart for daily IMO.
Mine is rediculious. Draws a good amount of power but its enough for my BTL so I dont see why it couldnt power 2 bl's. my BTL really moves with this amp and my voltage is dropping big time. very good amp im pretty sure its doing more than it says...
My Videos
AQ + AA/Fi FTMFW!!!!!
That would be just right for 2 BL's
As for your electrical, do the Big 3, and at least one extra deep cycle battery (yellow top, kinetik, powermaster)
Also, it would be a good idea to get a bigger alt but if you have enough batteries and don't play your music for hours straight, you should be fine with a stock alt, as long as it has decent amperage.
EDIT: Why are you going with the BL? Do you want SQ or SPL?
Edited by Kapetol T
thi vid is a single 10 inch fi bl runnin off of a dd z1 at .7 ohms and 1 kinetik 2400 and 1 kinetik 1400...meter a 139.8 legal in the dash and i ran it like this for about 6 months every day before i put the sub in my girls car off of 1500 watts...trust me a bl will take the power...before that the sub was ran off of a t20001 bd for almost a year... then it was reconed to the newer version due to tinsle breaking...
http://vids.myspace.com/index.cfm?fuseacti...ideoID=38881320
Edited by osixfrontier
99 4runner
orion hcca 8000.1d
2 2000x4 hifonics
320 amp singer alt
3 g31
thanks, and i'm from long island.
2004 gmc Yukon
MY YOUTUBE!!!
i would actually suggest the aq3500 over the 2200......and some battery and alt...
99 4runner
orion hcca 8000.1d
2 2000x4 hifonics
320 amp singer alt
3 g31
  • Who's Online   0 Members, 0 Anonymous, 2583 Guests (See full list)
