Sub Sonic
Split9112
wat do you try to set the sub sonic level to? is it to the tune of the box or to the fs of the sub or what? i have not had a amp with sub sonic filter on it till now. and was wondering wat i try to set it to
Live Fast Die Fun!!!!
Use it or lose it
I generally set them to right above 20Hz...... You don't want those LOW LOW notes to play through. Bad things can happen.
If the amp has enough power the sub can easily bottom out = Damage to teh woofa.
~Team Bad Company Captain
"It is the mark of intelligence to be able to entertain a thought without accepting it."
alright so i have a 10 ssd coming in and should i set the sub sonic filter to the Fs of the sub? jw. or wat should i try to set it to? jw
Use it or lose it
Use it or lose it
Just curious as to what amps you used to run
I set it to a hair below the tuning frequency of the box but it depends on how steep the slope is. Some amps have a 24dB/octave subsonic in which case you can afford to set it a little lower but keep in mind that if it's a 12 or 18dB slope then you'll still get substantial amounts of power below the crossover point. It doesn't take much power to unload a sub below tuning frequency as it's basically gone free-air.
EDIT: Also depends on the box... A small box with a small port you can afford to go reasonably far below tuning as the box will continue to provide a decent amount support to the sub, you'll just get lots of port noise... with a larger box or port (or very short ports) it will just unload and you'll get the happy sound of the coils pinging off the back plate, or if you have DDs the pleasant sound of the neck joint exploding :)
10.x volts fo' life!
  • Who's Online   0 Members, 1 Anonymous, 579 Guests (See full list)
