Posted (edited)
Alright guy's i've always been interested in "systems" and things regarding bass.
I would love to have a system, but do not know what to get any help is appreciated!
I do know i'd like to either have the FI BTL 15 (x2) or DC lvl4 15's (x2).
The amp, well I want the 3000D but cash is kinda low so i'm debating whether to get 2 1500D's for the time being.
I have no idea what the hell to get, any help?
BTW: The most wattage around here is 1500 so i want to make that look really shitty & shake the block :spiteful:
:hairtrick:
Edit: The backseat is going out
Edited by -z71.
if you dont know that much about car audio, start out small. dont jump into the expensive stuff right away. The BTLs are so touchy that the smallest thing could blow it, start out small and work your way up as you learn. Get yourself some nice MTX's ;)
"Buy some shit, Build some shit, Bang some shit!" - Dr. DB
Joe owns my soul.
Refs: Duct_Tape123, Derrick824
LV2 or 3's would be perfect.
Or you could scoop up some Mach 5 MJ's.
I love those damn subs.
Yeah starting off small is the perfect thing to do. Practice and then eventually get a bigger setup. Some Fi Bl or Fi SSD's loaded would be more than enough for starters.
You aren't going to get 2 1500D's any cheaper than you will a 3000D. I do think that you'd be better off with a pair of 1500's, but in no way are they cheaper than a single 3000.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
Lol i know some, i've been reading around for about 2 months now. Not going to wall it, ported box - forgot to say i'd like 2 amps for 2 subs lol.
I dont want anything that will barely shake anything in the house ( 1k-1500 rms )
I Want to shake the shit OFF the walls & amaze ppl at a stop light :)
Yeah i know that, but @ 2 rms the 3000 is only 1600 rms
But w/ that being said.....that means only 1600 rms is being produced not the whole 3000 righT?
People will not be amazed at stoplights. They will be annoyed.
It is childish and immature.
Shaking walls isn't that hard to do, I've done it with only 600w.
Go with some lower levels subs for your first system.
When you feel you need more you can always sell your old stuff.
Why do you want to run at 2 ohms. You can get dual 1 ohm subs and wire the coils in series and then parallel the subs to get 1 ohm at the amp and a 3000D puts out 3000 watts at 1 ohm.
1 XS Power D3100
Audio Control LC6i
Stock Deck
