Split9112 Posted October 21, 2008 Report Posted October 21, 2008 is this a good amp to use on a 10 fi ssd? wat would be a good one that is cheap that will give me the power i need and more at 1ohm for when i get another one. i am still a noob but around where i live i install a bunch of stuff and fix there stuff when they don't install it right. but i don't know much about wat amps give good wattage and which give bad. so thanks for the help Quote Live Fast Die Fun!!!! Use it or lose it
97maxima Posted October 21, 2008 Report Posted October 21, 2008 good ampfor themoney ,does that woofer have dual 2 ohm voice coils? Quote American Bass*DC Power
Split9112 Posted October 21, 2008 Author Report Posted October 21, 2008 it is dual 1 ohm Quote Live Fast Die Fun!!!! Use it or lose it
97maxima Posted October 21, 2008 Report Posted October 21, 2008 then thatampwould only see 2 ohms whats therms onthose subs Quote American Bass*DC Power
Split9112 Posted October 21, 2008 Author Report Posted October 21, 2008 800 rms Quote Live Fast Die Fun!!!! Use it or lose it
97maxima Posted October 21, 2008 Report Posted October 21, 2008 id look for a diff amp or a diff sub,that 1500 pushes plenty of power Quote American Bass*DC Power
Split9112 Posted October 21, 2008 Author Report Posted October 21, 2008 well the sub should be coming in tomorrow. so what amp would you recommend then Quote Live Fast Die Fun!!!! Use it or lose it
Nightshade Posted October 21, 2008 Report Posted October 21, 2008 If you're planning on getting another dual 1 ohm woofer then you'll need an amp that produces max power at 1 ohms not two. It you only plan on running one woofer then you would need an amp that produces max power at 2 ohms or even .5 ohms. This amp should be decent for then 10 right now and then when you get another dual 1 it will work even better since the amp will be wired to it's pull potential at 1 ohm mono. Quote 2013 VW Jetta GLI 2.0 Turbo 1 Sundown Audio SCV2000 1 Sundown Audio X15 V2 1 XS Power D3100 Audio Control LC6i Stock Deck 146.4 sealed on the dash at 37hz 2001 Focus ZX3: RETIRED Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore ChampionHighest NSPL Scores to date:154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz155.2db unofficial on dash at 43hz
Split9112 Posted October 21, 2008 Author Report Posted October 21, 2008 so the amp shold be good for a while then? Quote Live Fast Die Fun!!!! Use it or lose it
reinke Posted October 21, 2008 Report Posted October 21, 2008 i use 2 of these amps and i personally love them. the can be wired to .5 but you have to have a good electrical system and say bye bye to your warrenty if you have one. they do run hott as balls. thats the only complaint i have. Quote ----reference's---- meade916
