osixfrontier Posted October 21, 2008 Report Posted October 21, 2008 okay im getting ready to add my second z1 to my system...they will be strapped at 1.4 so each amp will see .7 BUT i have a rise of a little over 1ohm...weve checked.... im gonna run this daily and by daily i mean every single day as its in my beater car i use to go to work.. i have a ho'er alt on order from ho alternaters..its a 200 amp model that should idle 100 amps...i eventually plan 2 alts but that is in december sometime.....i have a volt meter and all so i can constantly moniter voltage... i already have a kenitik 1400 (under the hood) a g31 optima and 2 2400's....only 1 2400 is installed the other is on the side gonna install when i install the amp.. i also charge my batts via the kinetik charger over nite every other week or so. my question is is that enuff as far as batery goes so that i could full tilt a song or 2 for demo purposes car on of course...or should i get more battery (space is perty limited).... as it is now with just th 1400 2400 and g31 with 1 z1 and my slightly upgraded alt (90 as compared to stock honda 60) i stay at 12.8 or so at full blast....... i could do 1 more g31 or 2400 but i really dont want to if i dont need too....plus the weight is tad much for an 20 year old suspension.... 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
dmanson Posted October 22, 2008 Report Posted October 22, 2008 i'd sell off that g31 optima and get another HC2400 along with the MLA module potna. the optima only has like 55ah and around 750 CAs compared to the HC2400s 128 ah and 2600 CAs. you can always opt for a lil bit bigger alt too for a lil extra juice at idle. 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
automediapro Posted October 22, 2008 Report Posted October 22, 2008 I agree. . according to how Kinetik rates their batteries, just add up the model numbers. I would do the same thing. .Pull the Optima and put in the other HC2400 and see where you're at. . . Z1's are rated at 3000W, but I'd bet more. . Adding the 3rd HC2400 sounds like a plan!! in short. . x2 ( i guess I could have just said that lol )
osixfrontier Posted October 22, 2008 Author Report Posted October 22, 2008 i can get another 2400 if needed.. but the ptima is a g31 900cca and the ah isnt even listed..it kills when being loaded we load tested it a 500 amps and it didnd even drop past 10.9 after 15 seconds.... i get those cheaper then i get the 2400's...too i like it their as a a buffer ive had nothing but good results with that in the mix... so how much batter should i use.. 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
osixfrontier Posted October 22, 2008 Author Report Posted October 22, 2008 yeah my z1 tested out higher than 3000.... the 2400 on the battery is actualyy their ca rating not the cca rating the 2400 is rated at 1700 cca's....still more than the g31.... 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
osixfrontier Posted October 24, 2008 Author Report Posted October 24, 2008 okay well i put up y g31 for sale on a local forums for 160 Its only like 2 months old so i figure its a fair price for that big bitch.. and i orderd 2 2400's from my dealer and i gonna get it later today...so im gonna hace 3 2400's and 1 1400 + a 200amp alt.. is that good enuff for now? till like xmas time..... im my on kid so i get myself good gifts every year...this year will be a second alt and another batt...... and my fiance is getting a set of rainbow seperates and a zapco 4chanel........ 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
osixfrontier Posted October 24, 2008 Author Report Posted October 24, 2008 okay i picked them up i gotta get more wire now damit.........then i gotta build an amp rack and wire that big bitch up....... anywho is that enuff battry.... 99 4runner walled 2 18 fi btl ufo psi recones 15 cubes 33hz port bottom behind the C pillar orion hcca 8000.1d 8 Polk audio mm 691 6x9 2 2000x4 hifonics 320 amp singer alt 3 g31 1 baby seat 1 booster seat and daily driven!
Got_Bass89 Posted October 24, 2008 Report Posted October 24, 2008 Nice sounds good post some pics when there all in... Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
dmanson Posted October 25, 2008 Report Posted October 25, 2008 sounds like you're on a roll bro. don't forget the MLA module (could only help out a lil bit more). 2-DC 15XLM2 D.7s 1-DC 5K amp (1) XS Power D6500(UNDERHOOD) and (1) XS3000(REAR) 3 runs 1/0ga for power and 2 runs of 1/0ga for negative. (2)-RFT165s components, ...... 4 separate 1 inch tweetersRF T600-2(fronts) Punch 450.4(rear) Audiocontrol 3.1. DC power 260amp alternator w/MLA Module
