Need Lots Of Guidance And Opinions
ive been looking for a 4000 watt amp and i had narrowed it down to two choices... the rockford t4k or the mtx te4001bd. now if i had the money i would just go ahead and get the rock ford but the mtx is cheaper so im settling for that right now... i have a HO alt from iraggi (150idle/250max) and a yellow top for the setup that i have now and it does just fine. my voltage doesnt go below 13.5. HOWEVER.....
i would like to go bigger. my next setup is gonna consist of two 15 inch sundown nightshades and the mtx 4001.
now for the question.... i know i will need more batteries in order to be able to :hairtrick: . but i have no idea what i need to look for... i couldnt even find the fuse rating for the amp... but ive been seeing that brands like kinetic, power master etc are the brands of choice... i went to kinetics website and used there calculator and it said that i should us two of there 2400 cells. is this right and are there any alternatives... also another question is how long are these batts supposed to last before i have to let them charge? would i only have time for one song or would i be ok with a 30 minute ride at full tilt... like i said LOTS OF GUIDANCE AND HELP IS NEEDED
FOR SHIZZLE :aggressive:
2 Powermaster D3100's would work very well with one of those amps. If you find a battery with high amp hour ratings and a high discharge capacity that's more than likely a good battery. Some compainies will over rate their batteries and then you may not get what you're looking for. That's why you should stick to one's that have already been proven like the Powermasters. Mechman.com is a good place to pick them up at a good price.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
146.4 sealed on the dash at 37hz
2001 Focus ZX3: RETIRED
Team Sundown Audio, Team XS Power, 2 time NSPL Car 3601-Up Champion, 2 time NSPL Car Hardcore Champion
Highest NSPL Scores to date:
154.3db on the dash sealed at 46hz, 156.2db in the kick at 46hz
155.2db unofficial on dash at 43hz
They'll be okay by charging off the alt, but you should try and maintaince charge them once every two weeks or so to keep them healthy. I have yet to put mine on a charger and it still is holding a charge beautifully. It doesn't get much better than Powermaster.
1 XS Power D3100
Audio Control LC6i
Stock Deck
just looked on mechmans site and found this...
D3100
[D3100] $349.00
Click to enlarge
Features »
The preferred battery of champions!
Capable of delivering an astounding 3,200 amps of current
Provides major output for starting power, audio, multimedia systems, and more
Fits BCI group 31 applications utilized in many large trucks, busses and motor coaches
Can easily power systems up to 4000 watts when used as the main battery
Great supplemental battery for 5000+ watt systems
3 Year Warranty
Specifications »
Weight 77.16 pounds (35.00 kilograms)
Length 13.03 inches
Width 6.89 inches
Height 8.43 inches
Maximum Amps 3200
Ah 117
if thats true... could i just buy one and add it on to my yellow top and still be ok... or would two of those in addition to my yellow top be better...
with that said, with 4000 watts, you shouldnt be parking lot bumping
keep the car running and watch your voltage, 4000 watts is an assload of current draw
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
this wont be for sitting still... i only bump on the freeway... on side streets i always turn the subs off and bump responsibly... never ever will i bump while sitting still unless its a maitenance issue
still wouldn't hurt to put in two good batteries though.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
Whats your front battery? If its crap.. Your only strong as your weakess link... If crap bat up front.. I'd say yellowtop up front and D3100 in the back.. All 1/0 of course and Big 3... You can always get another D3100 if you need it later...
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
it would hurt my wallet... j/k :friends: but i understand the logic
yea i got a yellow top under the hood now(34/78) and the big three in 0 guage
  • Who's Online   0 Members, 0 Anonymous, 1333 Guests (See full list)
