What do you mean 4ga runs and a run of 0 for each t2k do you mean eaither or?
He means, a run of power and ground in 4 gauge for each T4004 and a run of power and ground in 1/0 for each T 20001bd
Guest Just_Rob
Justin, is your Blazer a 4 cylinder of V-6?? Either way you can do 200+ amps and have it be a direct bolt in... If it's a daily driver, make sure as it was mentioned that you buy something that gives you enough output at idle to run the truck and power the system.... Rob
or he could have meant 2 runs of 1/0 for the T2Ks .... 1 run of 4ga to the T4004s and ground the back batteries and eliminate the extra negative runs.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
OK so im gonna run 2 runs of 0 and 2 runs of 4 form the front bat to the back ones correct? They way I had it befor is I had one charge wire from front to back of the bat and then grounded the batts. Then connect the two +'s and then ran just one + to a spliter then to the amps. So is this going to be the same thing but with more runs?
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 hertz high energy 6.5s comps
4 stock ad244 alts
6 g31s batts
8 runs 0ga
O and it has a 4.3 vortec.
Edited by Justin
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Were can I get conection's that will work with that many 0 runs of 1 battery? Do I have to make some if so do you have any pic's?
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
Ok I have moved up to two memphis mojo 4kw. I was wondering how would I go about running at 16v for a daily driver?
99 2dr Blazer
Kenwood KVT-614
SounDigital SD16k
4 Fi BTL 18s
4 stock ad244 alts
6 g31s batts
8 runs 0ga
might want to research some on that 16v setup potna. it's dangerous .......... nall but look into it broham.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 998 Guests (See full list)
