(x1) Kenwood KDC-X979
to he honest, this is way to much for what i need/needed. it has so many features and options on it... Independent speaker leveling (Left Front, Right Front / Left Rear, Right Rear controls) and the list goes on, one bad ass Deck. just too much for me..
In Great Condition, 100% functional.
Price:: $200 + sh... no trades.--------- SOLD....
here is a list of the features :)
_________________________________________________________________________-
* KEY FEATURES 3D MASK 3-Dimensional 2-Piece Motorized Control and Display System
* Display Readout: 192 x 36 Dot Matrix, 8-Tone Ultra-Fine Pitch
* Dual-Zone Audio Control
* High Voltage Preamp Output: 5.0V
* High-Pass and Low-Pass Electronic Crossovers
* Kenwood Music Keg Ready
* Maximum Output Power: 50 Watts x 4
* Preouts: Front, Rear, CENTER, Non-Fading Subwoofer (Gold-Plated)
* Rotary Encoder Volume Control
* Plays MP3 and WMA-Encoded CD-R/RWs and Conventional CD, CD-R/RW Discs
* SIRIUS Satellite Ready
* System Q Sound Control: with User Memory
* LCD Display: High-Resolution, with Fluorescent Backlight
* GENERAL FEATURES 3D MASK 3-Dimensional 2-Piece Motorized Control and Display System
* 3D MASK Faceplate and Display Angle Adjustment
* 3D MASK Slide Angle Adjustment
* Clock
* Display Dimmer
* Finish: Silver
* Iso-Mount Capability for Japanese Vehicles
* Programmable Security Code System
* Soft Key Controls
* Sub Illumination: Blue
* Illuminated Function Buttons: Green & Red (Selectable)
* LCD Display: High-Resolution Color Multi-Mode, with White LED Backlight
* Touch-Tone Buttons: Defeatable
* POWER RATINGS Full Bandwidth Power (less than 1% THD): 22 Watts x 4
* AUDIO FEATURES 0-Bit Mute: Independent Left & Right Channel
* Attenuator with Smooth Volume Return
* Auxiliary Input
* Electronic Audio Control (Volume, Balance, Fader)
* Front/Rear Fader
* High-Pass Electronic Crossover: 40/60/80/100/120/150/220Hz/Through, 12dB/oct
* Preouts: Front, Rear, & Non-Fading
* Selectable Rear/Non-Fading Preout: with ± Level Control
* Source Tone Memory
* SRS WOW Sound Enhancement
* Telephone Mute
* Tone Controls: Bass, Midrange, Treble
* COMPACT DISC FEATURES 0-Bit Mute: Independent Left & Right Channel
* CD Text
* Digital Filter: 8-Times Oversampling
* Digital Optimum Servo Control
* Digital to Analog Converter: Integrated Quad 1-Bit
* Intro Scan
* Play/Pause
* Plays CDs/MP3/WMA, CD-Rs and CD-RWs
* Precision Digital Timing (DPAC)
* Random Play
* Repeat Play: Track, Disc
* AMPLIFIER FEATURES MOSFET Power Amplifier IC
* Muting Circuit for Internal Amplifier
* CHANGER CONTROL FEATURES CD Text Display
* Changer Control: 2, or 1 + Aux (with KCA-S210A or Compatible Changer)
* Disc Name Preset Play
* Disc Naming
* Random Play: Disc, Magazine
* Repeat Play
* Scan: Track, Disc
* TUNER FEATURES Automatic Memory Entry
* HD Radio Ready
* High-Speed Multipath Control (CRSC) with ANRC
* Internal Tuner Override During HD-Radio Operation: Automatic
* Kenwood CR-2 Advanced Tuner
* Seek Tuning
* Station Presets: 24 (18FM, 6 AM)
* OPTIONAL ACCESSORIES KPA-CP100 Compass
* KPA-HD100 Heads-Up Display
* KPA-SS100 Sensor Unit
* KTC-SR901 Sirius Satellite Radio Tuner
* KTC-WB100 Weather Band Tuner
Dolby Pro Logic II:
Dolby Pro Logic II processing reproduces any 2-channel source (even FM radio) into 5.1-channel surround sound, and outputs the audio through the unit's 5.1-channel, 5-volt preamp outputs. When in DPL II mode, you can select the Music, Movie or Matrix modes. The DPL II Music mode also has further "Fine" adjustments for Panorama (On/Off), Dimension (R3-R1/Neutral/F1-F3) and Center Width (0-7).
Audio Setup Modes:
In the main menu, you can select between two audio setup modes: Easy: gives you access to Cabin Size settings, Speaker Size Selection, Speaker Level Settings, and Call (to recall previous settings) Pro: gives you access to Crossover settings, Digital Time Alignment settings, EQ settings, Speaker Level settings, Memory (user/installer), and Call
Digital Signal Processor:
The KDC-X979's built-in DSP features the following adjustment that allow you to get optimal sound quality in every seat: Seat Position Settings: Using digital time alignment, you can adjust the output of each channel to put a particular seat (or seats) in the audio "sweet spot". You can select "Front Left", "Front Right", "Front" (both left and right), or "All" seats. Furthermore, you can enter precise distance measurements for front and rear speakers and subwoofer between 0 to 20.33 feet in 1/6-foot increments.
3-Band Parametric Equalizer:
The digital parametric equalizer lets you independently select the following EQ bands for front and rear channels:
Bass: Frequency: 60Hz, 80Hz, 100Hz, 120Hz, 160Hz, 200Hz, 250Hz, 315Hz, 400Hz
Level: -9dB, -7db, -5dB, -3dB, -2dB, -1dB, 0dB, +1dB, +2dB, +3dB, +5dB, +7dB, +9dB
Q Setting: 0.25, 0.50, 1.0, 2.0
Midrange: Frequency: 500Hz, 630Hz, 800Hz, 1.0kHz, 1.25kHz, 1.60kHz, 2.0kHz, 2.50kHz, 3.15kHz
Treble: Frequency: 4.00kHz, 5.00kHz, 6.30kHz, 8.00kHz, 10.00kHz, 12.50kHz, 16kHz
Cabin Size:
Selects one of the following vehicle sizes for best sound quality: Compact, Full size car, Wagon 1, Wagon 2, Minivan 1, Minivan 2, SUV, Minivan (long) or Off. Digital System E's + Advanced Crossover System: The Digital System E's+ Advanced Crossover system allows you to tailor your system with selectable crossover points for all channels.
You can independently set the crossover points as follows:
Front High Pass: 30Hz, 40Hz, 50Hz, 60Hz, 80Hz, 90Hz, 100Hz, 120Hz, 150Hz, 180Hz, 220Hz, 250Hz or Through (no filter)
Rear High Pass: 30Hz, 40Hz, 50Hz, 60Hz, 80Hz, 90Hz, 100Hz, 120Hz, 150Hz, 180Hz, 220Hz, 250Hz or Through (no filter)
Center High Pass: 30Hz, 40Hz, 50Hz, 60Hz, 80Hz, 90Hz, 100Hz, 120Hz, 150Hz, 180Hz, 220Hz, 250Hz or Through (no filter)
Subwoofer Low Pass: 30Hz, 40Hz, 50Hz, 60Hz, 80Hz, 90Hz, 100Hz, 120Hz, 150Hz, 180Hz, 220Hz, or 250Hz
Speaker Settings:
The Speaker Setting function tailors the System Q-EX Sound Control settings according to the type of speakers in your vehicle. You can select the following speaker sizes:
Front: O.E.M., 4", 5", 6-1/2", 6-3/4", 7", 4x6", 5x7", 6x8", 6x9", or 7x10"
Rear: None, O.E.M., 4", 5", 6-1/2", 6-3/4", 7", 4x6", 5x7", 6x8", 6x9", or 7x10"
Center: None, 2-3/4 x 1-9/16", 2", 4", 5", or 6-1/2" and over
Subwoofer: None, 6-1/2", 8", 10", 12", 15" and over
____________________________________________________________________________
(x1) Kenwood KCA-IP500 Ipod Adapter for the x979..
Price:: $30.00 + sh.
WILL DO PACKAGE DEAL IF BOTH BOUGHT @ SAME TIME
Edited by bangin_explorer
ROE Ref's-
Pornstar, Peas247, Speedcult, 98Tahoe,
2k1 sdime, 20blackls00, acidboy, t00sh0rt
KICKERASSMAN, TheDukey42, RapidFire89,
bass-aholic, xhilr8n , GavRiley2007, Jalat,
checkmate kstms, kingscratchie, F3RR3T,
Audiobahnfreak, + more...
SMD Ref's-
Chode69, kingsuv, pstone11, *1LOWSUV*, kbreudi, RatBass1998,
Applejack, jonathancullen89, Audioman21, Derrick824,
96saturnsl, Caps, spl explorer, littleitaly1990, tudski, sebXC,
mbdblue, j_black10, tre4chevyryda, zfrerichs...
CAC Ref's-
forceww, alex95sl2, canyouhearmatt, flores210, Anime Freak,
iamtheone, dcmcki, rcpease, jigga jatt, mytyeerinpie...
THAT IS TRUE SUB PORN...got some sexy movement and a squirter spewsmiley.gif
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
ROE Ref's-
SMD Ref's-
CAC Ref's-
don't sleep on this Kenwood. its a bad ass deck bump.
ROE Ref's-
SMD Ref's-
CAC Ref's-
All I need to do is sell a multi battery charger and I can scoop this up. Hell of a deal man. Like I said, if it doesn't sell before I get the money, I WILL buy it. But post when it sells man.lol
interest on craigslist.. get it now b4 its gone.. package deal if both items are bought.
ROE Ref's-
SMD Ref's-
CAC Ref's-
SOLD... can close.. thanks.
ROE Ref's-
SMD Ref's-
CAC Ref's-
This topic is now closed to further replies.
  • Who's Online   0 Members, 1 Anonymous (See full list)
