marquettefan247 Posted October 28, 2008 Report Posted October 28, 2008 I have to finish wiring my subs First time ever doing it i have to put the fuse in the block hook power to amp power amp ground and connect subs. any help how do do this and what order i should do it in its my first time doin it. 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
Chode69 Posted October 28, 2008 Report Posted October 28, 2008 ground first fuse last....hook up the ground and power wire WITHOUT THE FUSE in it. that way if some wires to do touch theres no power. once all wired hook put in the fuse NoFearX18 said: Nick will bang just about anything.....LMAO....pun intended On 4/13/2010 at 9:51 AM, meade916 said: i was like DAMN, Chode is hardcore! he makes james look like a friendly person LOL! trainman0978 said: I dont know who is worse with the buttholes Chode or Big P... Team Deadly Hertz / Team DC Audio / Team XS Power 2010 DC AUDIO MEMBER OF THE YEAR!!! DuckretaryFEAR THE DUCK Durangho Chodes Blowthrough Build Youtube vids Muh Wife Need DC Audio? Hit me up for pricing!!!
marquettefan247 Posted October 28, 2008 Author Report Posted October 28, 2008 how do i test my ground? 1995 Ford Mustang 3.8l V6 5 Speed Plans: 2 12 inch dc Level 4s DC 2.0k Amp KCA 1/0 Power Amplifier Installation Kit 220 Amp Alt XS Power 12V D925 AGM Battery Stinger Volt Gauge Rockford Fosgate RCAs Box built from birch. Probably tuned to 32 Hz 0 gauge wiring for extra battery Dynamat “I think everyone should go to college and get a degree and then spend six months as a bartender and six months as a cabdriver. Then they would really be educated.” Al McGuire “The only mystery in life is why the kamikaze pilots wore helmets” Al McGuire remember this always Close only counts in horseshoes and hand grenades
Neo_frog Posted October 28, 2008 Report Posted October 28, 2008 how do i test my ground? For your ground, just make sure that you're not screwing into sheet metal! It should be a solid piece that you drill out or an existing ground or bolt somewhere in the chassis. You should use self tapping screws, or just make your own with bolts washers and nuts. Just make sure you strip the paint off with sand paper where you'll be creating the ground if you do that. I'm guessing it's a trunk system (?). Just pull the carpet back and there should be bolts and nuts all over that are possibilities. Hook up the amp before putting the fuse in like he said and all should be well. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
inline audio Posted October 31, 2008 Report Posted October 31, 2008 yup they gave u good info i would so the same.
