Split9112 Posted October 30, 2008 Report Posted October 30, 2008 i am trying to get the most out of my small amp and was wondering the best setting? wat do you set your stuff to? the bass is set at 0 on the h/u the gain is like 3/4 the way up the bass boost is on 0 and the lpf i think is around 80 hz Live Fast Die Fun!!!! Use it or lose it
alvitae Posted October 30, 2008 Report Posted October 30, 2008 I have my small amp set up about the same way except my gain is a lot lower than yours. I read that the gain is for matching the h/u's voltage to the amp. Since my h/u puts out 2 volts I have my gain set at 2 volts.
wL<3bass Posted October 30, 2008 Report Posted October 30, 2008 i am trying to get the most out of my small amp and was wondering the best setting? wat do you set your stuff to?the bass is set at 0 on the h/u the gain is like 3/4 the way up the bass boost is on 0 and the lpf i think is around 80 hz Where the knob is positioned mean absolutley NOTHING to us....your gain is an adjustment to compensate for headunits that have varying output voltages.... You take a dmm look up the RMS your trying to get off an RMS chart yurn your knob til it reads the proper voltage (AC) at a specific ohm using a 50hz sine wave, once you have done that use an oscilloscope and check for clipping. edit: Heres a tutorial JL made its pretty helpful if you don't know what you are doing.....Oh yeah and if this is for your full range speakers (ex. coaxials, components, aka door speakers. Use a 1khz/1,000hz sine wave and a 50hz for subs) Click for tutorial! Vehicle: 1997 S10 Blazer 4dr 4X4 Exterior: Rear End Bagged, Black Grill, Lifted 2" Amplifiers: Rockford Fosgate T8004 & T10001bd Batteries: 2 Stinger SPV35, Kinetik HC2400 Electrical: Big 3, DC Power 290amp Alternator w/ MLA at 15.5v Enclosure: 4.2 ft³ @ 33Hz 84sq.in. of port (20sq.in. per cube) Headunit: Eclipse CD3200 w/ 80G iPod Mids/Highs: Rockford T152s (a-pillars), Rockford T162s (doors) Subwoofers: 1 15" Fi BL Fully Loaded Wire: All 1/0g Kicker Hyperflex My YouTube Videos My Fiberglass A-Pillar Build My "Seamless" Looking Box Build My DD1508 T-Line Bandpass Build "Seamless" w/ Acrylic Windows (for '05 TrailBlazer) My Stealth 8" Fiberglass Build (for '05 TrailBlazer) My Build For A Friend's '08 Cobalt 15" BL Sealed Off From The Trunk My feedback/references...
Split9112 Posted October 30, 2008 Author Report Posted October 30, 2008 I have my small amp set up about the same way except my gain is a lot lower than yours. I read that the gain is for matching the h/u's voltage to the amp. Since my h/u puts out 2 volts I have my gain set at 2 volts. ya for some reason it is not as loud as i thought it would be but tomorrow i am going to lower the gain again to see if it was just b/c it was cold out tonight. and to see if it changes if have the truck running Live Fast Die Fun!!!! Use it or lose it
Boon Posted October 30, 2008 Report Posted October 30, 2008 Bring the LPF up a bit. When you're lacking power you can often make up for it a little (acoustically, means nothing to a meter) by letting the subs play a bit higher. 10.x volts fo' life!
a_steezy Posted October 30, 2008 Report Posted October 30, 2008 just turn everything all the way up!!!!!!!!!!! max that bish out atomatic maaaaaaaaaad debeeezzzzzzzzzzzzz '98 Dodge Durango 5.9L 5% front windows, 2.5% on all backs Alpine CDA-9883 Kicker ZX350.4 Kicker KS650's in all doors Kicker 1/0 hyperflex
Boon Posted October 31, 2008 Report Posted October 31, 2008 just turn everything all the way up!!!!!!!!!!! max that bish outatomatic maaaaaaaaaad debeeezzzzzzzzzzzzz Man I hope you're taking the piss, if not I'm not surprised your amp is always broken. 10.x volts fo' life!
