Neo_frog Posted October 31, 2008 Report Posted October 31, 2008 First off, I don't even know if it's really an issue, but I've heard that my voltage should be between 13.5 and 14.x but even with my current setup it doesn't go above 13.4V unless I'm driving. I have a 300A Iraggi alternator, 4 Kinetik HC2400 batteries and Big 3 with double 1/0 Am I missing something? BTW this is with car idling with no other loads. ...oh and while driving the highest I've seen is 13.7 Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Guest Posted October 31, 2008 Report Posted October 31, 2008 different cars have different charging voltages, if you really want to upgrade the charging voltage, get an MLA Module (theres a section on here for that)
Gotloud555 Posted October 31, 2008 Report Posted October 31, 2008 First off, I don't even know if it's really an issue, but I've heard that my voltage should be between 13.5 and 14.x but even with my current setup it doesn't go above 13.4V unless I'm driving.I have a 300A Iraggi alternator, 4 Kinetik HC2400 batteries and Big 3 with double 1/0 Am I missing something? BTW this is with car idling with no other loads. ...oh and while driving the highest I've seen is 13.7 I heard that Iraggi atlernator doesn't put out volt at idle only if you raise the RPM. It's isn't a big issue. What does your voltage say under the hood right now?
Neo_frog Posted October 31, 2008 Author Report Posted October 31, 2008 I heard that Iraggi atlernator doesn't put out volt at idle only if you raise the RPM. It's isn't a big issue. What does your voltage say under the hood right now? While running, 13.4V. I haven't measured it off the alternator though since it's damn near impossible to get to. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
Neo_frog Posted October 31, 2008 Author Report Posted October 31, 2008 Krannyman92, thanks for the info on the MLA module. That's exactly what I needed! Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
