something's not right because your batteries should be resting higher than that.
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
i took some voltage readings.
at the alternator 14.03 volts
battery under the hood car running 11.5x volts
battery in back car running 11.4x volts
battery under hood car off 12.01 volts
battery in back car off 12.00 volts
So apparently my alternator is fine.
ANY and all help is greatly appreciated
Sounds like you have a small drag somewhere. Think about it if the positive wire at the alt is 14.03 then that wire should go straight to the battery and it should read the same thing. I would start disconnecting accessories until this issue is solved.
Member since 25 Jun 2006
2011 Yukon DenaliCustomLightz 4300K HID RetrofitEsky TailsEsky Third BrakeEsky 22sEsky Appliques
Random vids of the Avalanche My link
Team Bass-Hz
  • Who's Online   0 Members, 0 Anonymous, 929 Guests (See full list)
