What Is This Box Tuned To?
outer dimensions 22*41*28
inner dimensions 19*38*25
port dimensions 4*38; 19" long
bracing displacement 144.1square inches.
sub displacement 449.28 square inches...
wood thickness was 1.5"
A vitrolic, megalomaniacal sadistic psychopath.
Without woofer displacement it is roughly tuned to 31hz. It actually says in the port calculator that I used it is not in the 1:8 port ratio that should be followed to eliminate port turbulance. Your port is 4" tall X 34" wide which is a 1:9ish ratio. I'd try making the port a heigth a little wider or cut the width of the port down a few inches.
2013 VW Jetta GLI 2.0 Turbo
1 Sundown Audio SCV2000
1 Sundown Audio X15 V2
1 XS Power D3100
Audio Control LC6i
Stock Deck
2001 Focus ZX3: RETIRED
Highest NSPL Scores to date:
if I cut the width down would that raise tuning a little, I want it at least at 33 preferably 35ish.
basically I built the box but only had a very limited time to do it so without really thinking about it I put the port along the length of the bottom instead of the length of the side, and I really don't feel like having to rip the front off and port and remake it if I don't have to.
  • Who's Online   0 Members, 0 Anonymous, 4824 Guests (See full list)
