1970 Ford F-250 Sub Install?
Got a chance to buy one off a coworker for 1 grand.
Would it be possible to install a sub or two in it, or no? Is the gas tank in the cab?
Is it possible to put one in the cab, yes. I believe the gas tank is in the cab.
Not sure what your budget is on it, but if you want it behind the seat, you could get a fuel cell and put it under the bed.
If that is out of the question then is it a bench or bucket seats. If its orginal then it is going to have a bench.
You could always swap out the bench and put buckets in, again dependent on budget.
Another thing you could do is put the sub on the tranny tunnel as long as its a automatic, if its a maual, then the other 2 ideas could work.
The last thing you could do is build a 4th order box, or 6th order box and have it under the cab bolted to the frame and cut a hole into the floor for the sound to come in.
It can be done its just dependent on which way you want to do it.
formerly known as Blue86f150
this sux camel dicks
Ah, yes the fuel cell idea did come to mind.
Thinking I'll probably do that, along with bucket seats, hello 3-4 12"s. :D
better look into shallow mounts. only thing your gonna fit in a regular cab and not be on the steering wheel.
  • Who's Online   0 Members, 0 Anonymous, 1597 Guests (See full list)
