1st up to bat. 1 Hifonics 1206d amplifier $170+ shipping OBO
specs::
Number of Channels  1 - Mono
RMS Power (4 ohms)  450 watts x 1 chan.
RMS Power (2 ohms)  900 watts x 1 chan.
RMS Power (1 ohm)  1200 watts x 1 chan.
Bridged RMS Power  Not Bridgeable
Peak Power Output  N/A
Min. Impedance Unbridged  1 ohm
Min. Impedance Bridged  N/A
THD @ Rated RMS Power  <0.1%
Speaker Level Inputs  Yes
Amp Preamp Outputs  Yes - 1 Pair
Built-in Crossover  Yes - LP
High-Pass Crossover  N/A
Low-Pass Crossover  35 - 250 Hz
Subsonic Filter  15 - 50 Hz
Signal-to-Noise Ratio  >95 dB
Channel Separation  N/A
Bass Boost  0 - 18 dB
Bass/Gain Remote  Yes
Fan Cooled  N/A
Fuse Rating  80A
pictures
2nd item    1 12" wmd sub  $80+shipping
specs::
#WMD12
fs = 28hz
qes = .84
qms = 6.37
qts = .74
vas = 1.6^ft3
mms = 173g
sens = 87.9 db @2.83vrms
voice coil overhang = 18mm
nominal impedence = dual 2 ohm
pictures
3rd item 1 12" infinity kappa perfect dual 4  $50+shipping OBO
specs::
·        12" dual 4-ohm subwoofer
·        aluminum cone with high-roll butyl-rubber surround
·        massive cast-aluminum basket
·        suitable for free-air use (handles up to 175 watts in free-air applications)
·        power range: 75-350 watts RMS (1,400 watts peak power)
·        frequency response: 18-200 Hz
·        sensitivity: 96 dB
·        top mount depth: 6-1/8"
·        sealed box volume: 1.0 cu. ft.
·        ported box volume: 1.75 cu. ft.
pictures
4th item    4 eminence apt-80 supertweeters  $80+shipping
specs::
APT:50
SPECIFICATION
Throat Size  1", 25.4mm
Nominal Impedance*  8 ohms
Power Rating  45W @ 3.5kHz, 85Wrms @5kHz
Resonance 2.5kHz
Usable Frequency Range  3.5Hz - 20kHz
Sensitivity*** 105dB
Magnet Weight  7.75oz, .22kg
Voice Coil Diameter 1.0" / 25.4mm
THIELE & SMALL PARAMETERS
DC Resistance (Re)  6.3
Coil Inductance (Le)  1.5mH
MOUNTING INFORMATION
Overall Diameter  2.75", 70mm
Mounting Holes Diameter
Mounting Holes B.C. D.
Mounting Thread
Depth 1.57", 40mm
Weight  1.5 lbs, 682 kg.
MATERIALS OF CONSTRUCTION
Diaphragm Material Phenolic
pictures
5th item    kenwood soft dome tweeters (very smooth sounding)
sorry specs no longer available
pictures
- ROE Refs- Majorpayne, Roe, Ceestaypropa, bandcamp, Dumple91, pimpedout97x, Corey anderson, JEXTEL- CA Refs - rtillaree, Rich00 Seismic Disturbance C.C Riverview FL.
i have the same amp in my buddy's daewoo with the same ssd im gettin and it has it only movin at about half the xmax it can plus it has alot more potential thats why im selling it to get a bigger amp about 1500-2000 rms for each ssd
is that your rock bottom on that amp, i may have someone here local to me that wants it
$170 is the lowest i will go without shipping
The 1206d has at the very most of 3 hours of play, was on 1/0 gauge wiring so it wasnt struggling to get the power it needs and damage something
update::
eminence tweets sold
wmd is spoken for
infinity might be taken by toyota thundra for HT use
and the rest is waiting for a good home
:whistling:TTT
TTT
TTT i need this stuff gone asap
