the person i purchased the sub from failed to tell me about a stripped out set screw for one of the terminals. wouldnt have known until i went to install it, but i found a thread started by him a long time ago on another forum.. asking how to get a stripped set screw out, just like i am now.
its an allen head bolt. ive tried going a size up, doesnt fit. ive tried flat head screw drivers, nothing. i dont want to spray anything on it to free it up either. any ideas? could i drill it out? ive heard i can get a new set for $15 or so from RE.. but id like that to be the last resort... if i can get it out, i can at least replace just the screw itself.
thanks in advance.
Wasted, Incorporated
Up Front: Optima Yellowtop
HU:Pioneer Avic N1 w/ 2007 upgrade
Front Stage: MB Quart 6.5 comps
Rear Fill: Infinity Reference
Sub Stage: RE MT 18
Sub Amp: Undecided
Sub Enclosure: 5.5 cubes tuned to 33hz
Absolute Terminals
SkyTec 5100RS 2-Way LCD Pager
KnuKonceptz Wire
My Build Log
thanks in advance.
Easy outs FTW! usually works in most cases small pilot hole then use the easyout
Something like this set should work
http://www.amazon.com/Easy-Out-Screw-Extra...t/dp/B0002SDAIY
1 15" Nighthade
Sundown 1500D
3.4cubes @ 34
yea i thought about easy outs, ill try to get my hands on a set. i wont be installing for a while anyways. all other ideas are welcome. thanks guys.
Sub Stage: RE MT 18
Sub Amp: Undecided
Absolute Terminals
KnuKonceptz Wire
My Build Log
Get a punch and a hammer and gently tap the punch on a flat top part of the set screw to make an indention then angle the punch while still in little hole and tap it around and around until it comes out.
My YouTube Videos
My Fiberglass A-Pillar Build
My feedback/references...
id do that, but the set screws are just a hole for an allen wrench - theres really no top to them. ill try and get a point on the inside of it tomorrow though, that may work. thanks for the input man
Sub Stage: RE MT 18
Sub Amp: Undecided
Absolute Terminals
KnuKonceptz Wire
My Build Log
yea, thats probably the route ill end up taking. thanks bud
Edited by wasted ink
Sub Stage: RE MT 18
Sub Amp: Undecided
Absolute Terminals
KnuKonceptz Wire
My Build Log
ive had easyouts snap on me into the set hole and then you're double fucked cuz those easy outs are really hard (but apparantly brittle) material.
just a word of warning, spend the extra few bux and get a good set
Team DC
yea, will do. ive used easy outs before, just not on such a small fastener.
the reason they are hard but brittle is because theyre usually made of high carbon steel.. resulting in an extremely hard piece yet brittle like cast iron ;)
Sub Stage: RE MT 18
Sub Amp: Undecided
Absolute Terminals
KnuKonceptz Wire
My Build Log
