superduper Posted November 13, 2008 Report Posted November 13, 2008 What would you prefer: two z1's or a z2lv? z1: 1 x 3000W @ 1 ohm (14.4V) 1 x 5000W @ 1 ohm (16V) Efficiency: <85% Bench tested by Peter.T from Soundpressure.com (Sweden): 12 Volts: 4.6 ohms = 2279W 2.3 ohms = 3405W 1.15 ohms = 4188W 14,4 Volts: 4.6 ohms = 3042W 2.3 ohms = 4461W 1.15 ohms = 5358W z2: 1 x 6000W @ 1 ohm (14.4V - 1% THD) Efficiency: <74% Bench tested by Peter.T from Soundpressure.com (Sweden): 12.5 Volts: 4.6 ohms = 2045W 2.3 ohms = 3260W 1.15 ohms = 3561W* 14,4 Volts: 4.6 ohms = 2975W 2.3 ohms = 4377W 1.15 ohms = 5248W 17,5 Volts: 4.6 ohms = 3962W 2.3 ohms = 6503W 1.15 ohms = 7947W Quote
audiofanaticz Posted November 13, 2008 Report Posted November 13, 2008 those specs are old, so old that those amps are not even being made no more. The specs look like the first gen dd Z1 and Z2. Then the Z1a came out, and replaced the z2 and z1. Now there is a Z2 lv and hv (low volt, high volt). these amps take over the older Z1a's Charger on this site is running 2 DD Z2 LV's in his ride. Specs on these amps from DDs site. Quote
Boon Posted November 14, 2008 Report Posted November 14, 2008 Z2LV hands down. The Z1's likes to blow up unless they're Z1a's but even then you're talking old gear vs new gear. Quote 10.x volts fo' life!
